Question about LG WM-2277HW Front Load Washer
LG Tromm WM227HS LE code error - LG WM-2277HW Front Load Washer
  • 5 Answers
SOURCE: LG Washer
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Posted on Dec 08, 2007
rickzilla
  • 706 Answers
SOURCE: LE Error Code on Tromm
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
Posted on Sep 20, 2008
  • 23 Answers
SOURCE: Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Posted on Apr 25, 2009
SOURCE: LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
Posted on May 16, 2009
SOURCE: LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
Posted on May 31, 2009
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
On a LG Tromm washer, what does error code ''LE'' mean?
LE indicates the motor is locked. Check the 3 pin connector at the motor and check the 4 pin connector at the main control if they look good ( no corrosion and fit tight) replace the Hall Sensor. You can enter your model # at www.appliancehelponline.com for diagrams and illustrations.
May 28, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
LE error code
Ther should be a booklet located in your machine, that will explain each error code. It is usually located in the bottom panel or up in the console.
Jan 14, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Sep 14, 2009 | Washing Machines
LE Tromm Washing Machine
i think you mean LG Tromm washing machine ... and the error code is LE ... thats a common failure with this machine .. often its cause by a defective " Hall effect sensor" this is used to detect the position of the wash basket ... if you are handy with tools then you can change it yourself at low cost ... but it does require removing a big bolt, the spin basket and several small bolts ... not difficult for a mechanic but probably more than aunt martha would want to tackle .. the URL listed below will give you good information on how to do that job ..
http://www.howtomendit.com/answers.php?id=28214
Aug 18, 2009 | LG WM2688HWM TROMM SteamWasher
My lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Jul 14, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
89 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
