Question about Philips 15PF5120 15 in. LCD Television
Have no sound or picture, Just black screen. Power button comes on green but few minutes later turns amber
bluegreenash
  • 661 Answers
SOURCE: no picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Posted on Sep 27, 2007
  • 9 Answers
SOURCE: Screen says attention no signal
Your TV is probably on the PC mode and you are not using it as a PC monitor.
You need to change the source by pressing the TV/Video button on the remote control or the SOURCE button on the TV itself. You may also just press the channel up or down buttons. Do this before the TV goes to standby mode (amber light) or while it shows the message: ATTENTION NO SIGNAL.
If it does not work, reboot the TV first and do this again.
Posted on May 18, 2008
daniel719
  • 240 Answers
SOURCE: TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Posted on Jan 12, 2009
pwrblnc
  • 4 Answers
SOURCE: TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Feb 28, 2009
roety
  • 585 Answers
SOURCE: MAGNAVOX 32MF605W/17
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Posted on Sep 26, 2009
I have a Toshiba 50HM66 DLP TV. I turn it on and after a minute or two the screen goes black but the volume is still present most of the time. The picture may come back a few minutes later but go again.The...
I hope our expert would have provided you helpful info in chat session, if you still need further help, let me know the steps taken so far to solve the problem of your tv.
Thanks.
Sep 18, 2010 | Toshiba 50HM66 52" Television
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
When I press the power button the unit turns on but the screen is black, then after a few minutes the sound goes out and the green light flashes and then it comes back in. The sound only still no Picture....
Hello if its been close to two years since you brought the unit , Then its time for a new lamp. Replace the lamp and your problem will be solved...
Please leave a comment THKX
Oct 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Philips 15PF5120 15 in. LCD Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
