Question about Dell E152FPb 15" TFT LCD Flat Panel Monitor
Philips 191el monitor brightness setting - Dell E152FPb 15" TFT LCD Flat Panel Monitor
Model 191el. Controls locked. How do I unlock?
you will have to contact the manufacture to see if theres away round the pass code, next time no code or use what the manufactures uses 0000 or the last ssn. last 4 phone #.
Oct 02, 2015 | Philips Computers & Internet
Philips dcb152 05 display is very dim it's almost un-noticable. Is there anything i can do to make it brighter
yes. You can always use the contrast and brightness tabs in the monitor.
Go to the MENU of the monitor by pressing a button(prob it should on a side of the monitor).
Choose brightness and then increase it.
May 24, 2014 | Philips Televison & Video
Where is the menu touch button located of 191EL phillips
Per user guide on page 5 at the bottom left column it sates "buttons at the front bezel of the monitor" So it could be the imprinted icons on the bottom right hand of unit as shown on the picture or underneath it.
http://download.p4c.philips.com/files/1/191el2sb_27/191el2sb_27_dfu_aen.pdf
Dec 14, 2012 | Computers & Internet
How to open the cover of 191el lcd monitor
i just open my philips 191EL monitor by lifting slowly the upper front plastic panel of the screen with a light press away from the screen. then lift going to the right side and going to the left. thats it.
Dec 14, 2011 | Philips 191EL1SB75 Monitor
My philips 191EL LED monitor was not functioning the menu buttons but have a display and in use while plug on, however, at below portion of the screen appears the word SmartImage on and SmartImage off. Is...
simply long press input and power touch buttons to reset the ic program and it will be ok be sure to wait 5-10 seconds note: be sure the led has display input and powered on with the problem your encounting thanks ok
Jun 10, 2011 | Philips Computers & Internet
Sir, my philips 202E line series monitor has been locked and while operating touch sensitive controlas on it I receive a msg "monitor controls locked" and not able to adjust brightness of my...
sir, my philips 202E line series monitor has been locked and while operating touch sensitive controlas on it I receive a msg "monitor controls locked" and not able to adjust brightness of my monitor.
thank you
Sep 30, 2010 | Computers & Internet
How can i unlocked the menu of my philips lcd monitor i70t4?? pls help me i cant configure the settings of the brightness and everything..
Question My monitor shows the message: OSD MAIN CONTROLS LOCKED. What can be the cause of this message? Answer To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC.
User manual, support, FAQ: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=190B6CS/00&slg=en&scy=GB
Apr 27, 2010 | Philips 190B6CB/27 19" LCD
Philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Dec 06, 2008 | Philips 170S6FS 17" LCD Monitor
Dell E152FPb 15" TFT LCD Flat Panel Monitor Logo
105 people viewed this question
Alun Cox
