Question about Canon Pixma Pro-100
Print quality not equal to monitor view - Canon Pixma Pro-100
New toner but printed output is too light and faint. What can I do?
Hi there !
You need to replace the drum unit of the cartridge and i believe that the part life had ended. you can view this on the LCD monitor of the printer. Go to menu and choose LAN setting. Choose machine parts and check the drum unit is it says life ended. You need to replace that drum unit.
Another way for temporary purposes, set your print quality setting to PHOTO setting. It will print darker than before but not on taking photocopy.
Feb 09, 2011 | Brother MFC-7820N Laser Printer
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Poor color quality (Canon Pixma pro 9500)
recalibrate the printhead, clean the printhead. In the printer driver you need to select the right paper.
Jun 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
No red colour in my lg lcd monitor ..red colour setting doesnt bring any change i screeen..pls suggest some solution
it is very simple, by default in monitor circuit RGB (Red, Green, Blue) tube is installed. and in combination of both of three colors we are able to view colorful image. due to non functionalty of Red color u r not able to view red color in screen, either you replace picture tube or purchase new monitor. coz cost of this tube is equal to monitor.
Jun 05, 2009 | LG Flatron F700P 17" CRT Monitor
Helo i have got a nokia 5300 black express music phone and i brought these mobile phone twin music speakers for them but i dont know how to set them up so please can u help me thnks
Equalizer
You can control the sound quality when
or diminishing frequency bands.
Select Menu > Fun & Apps> Media > Equalizer.
To activate a set, scroll to one of the equalizer
To view, edit, or rename a selected set, select
Not all sets can be edited or renamed.
Stereo widening
Stereo widening enhances the audio output of the phone by enabling a wider
stereo sound effect. To change the setting, select Menu > Fun & Apps>
Media > Stereo widening.
Mar 25, 2008 | Lands Phones
Image qulaity problem in fujifilm finepix fd50
It sounds like the resolution on the monitor may be set incorrectly in Photoshop. Try a different monitor setting. Twelve megapixels may result in your monitor "seeing" so many pixels it tries to ignore the excess ones, resulting in an image that looks poor on your monitor. If you order one print, that may give you an idea of the true printed quality without spending a lot of money on a bunch of bad prints. The F50 is truly an excellent camera and gives super images, from my experience.
Mar 02, 2008 | Cameras
Resolution
Press the MENU icon (middle icon) on the left side of the LCD screen. Then press the QUALITY icon (lower row left icon). Choose from one of the four icons. One symbol equals VGA (640x480) (standard quality). Two symbols equal ECONOMY (1024x768) (standard quality). Three symbols equal STANDARD (1600x1200) (standard quality). Four symbols equal HIGH QUALITY (1600x1200) (highest quality)
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
E-mail images
What is the Macro function used for? The Macro function allows you to take close-up pictures. Use the Macro mode when you are 8.4” to 19.2” away from your subject. Where is the Reference Manual for the D-390? The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer. How can I get traditional photo prints from my digital camera? Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer. Why are there so many quality settings? Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images. What settings should I use to get the best picture quality? The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K. What is the video output used for? The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR. When taking macro images, can I use the viewfinder? Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken. How do I make a Panorama picture? You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation. What is movie mode function? The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode. Can I add sound to a movie made with my D-390? The D-390 does not record sound in the movie mode. What is the best way to e-mail images? E-mailing pictures that were taken with your camera is as easy as attaching a file to your message.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Canon Pixma Pro-100 Logo
21 people viewed this question
old marine
old marine
