Question about Speed Queen Washing Machines
Hi, I need help with Speed Queen Top loader model #AWM551W (S/N R9207039223) leaking from bottom. I believe the seal is bad. How do I remove the tub ring without breaking it, all videos show easy release tabs that this model does not seem to have.
2 Suggested Answers
  • 254 Answers
SOURCE: Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Posted on Feb 03, 2010
Good day, can you please help, I want to know what can be the problem. Our speed queen heavy duty washing machine leaks water when spining. The water leak is at the top of the outer tub where the clips...
The basics would be make sure it's clean, the outer and inter ring of this area holds and builds up dirt and debris over time, causing a bad seal, also has to spin and be balanced properly or it will leak a little. ...
Feb 26, 2015 | Speed Queen Washing Machines
LG fuzzy logic top loader leaves black marks on white. Happens when doing a large wash-eg; blanket -it looks awful. I'm thinking the insides might need cleaning? How is this done and with what product
If this is moldy looking you should use 1 cup of bleach in the drum with no clothes on the longest wash cycle with the hottest water. But I believe this is oil from the drive train and the seals on the bottom of the drum are going bad. When you wash something heavy like the blanket, it leaks.
Nov 25, 2013 | Washing Machines
Speed queen top load washer leaks
Is it a bad leak like it will not fill up with water or just a small leak.
If it will not fill up it most likely is the tub seal. If it is a small leak it might be the water pump seal. There are two screws at the base of the machine that takes a 5/16" or a 8mm socket to remove them.
remove the front cover and start the machine filling and watch for the water DO NOT STICK YOUR HAND IN SIDE THERE WHILE THE MACHINE IS ON!!!! Here is the repair manual for your machine.
If I was you I would repair the machine instead of replacing it. these are awesome machines I have 20 of them in my laundromat that are 19 years old and still trucking every day. the seal is some work you will need some tools and a 3 jaw puller to replace it but you can rent them at most auto parts stores. If it is the pump that is a simple fix just remember to clean and grease the end of the shaft .
here is the repair manual for your machine and the number should be AWZS52
http://www.partsking.com/pdf/201142.pdf
here is the seal kit
http://www.partsking.com/mm5/merchant.mvc?Screen=PROD&Store_Code=pk&Product_Code=766P3A&Category_Code=
here is the water pump
http://www.partsking.com/mm5/merchant.mvc?Screen=PROD&Store_Code=pk&Product_Code=201566P&Category_Code=
GOOD LUCK
Jan 22, 2013 | Speed Queen AWS52NW Top Load Washer
Model #AWM392W when water is filling tub, water is coming out from around the bottom
the outer tub seal is bad,you need to remove the inner tub then outer tub to replace this seal
Aug 07, 2011 | Speed Queen AWS52NW Top Load Washer
When the spin cycle begins the washer vibirates and moves on the floor. After the spin cycle reaches the maxium speed it stops. The springs are fine, but what else could be wrong?
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Jul 25, 2011 | Speed Queen AWS44NW Top Load Washer
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Bearing or gearbox noise on spin
It is a pleasure for me to offer some assistance to users all over the world. The problem you are describing to me is a very common for any amana, speed queen washers. The tub seal leaks and washes the lubricant from the upper bearing making the roaring noise in spin. The bearing needs replacement now, also the tub seal comes as a kit to rebuild all the sealing surfaces. It also does require a complete dissasembly to install the new kit plus the bearing. I would charge 3 hours labor @ 75/hr and the parts would be around $100 for the hub-n-seal kit and the bearing. However you may want to consider a new machine with a better warranty (extended warranties are a MUST these days......BUY ONE with any new appliance. Hope this helps let me know if you have any questions. Unfortunatly these Speed queen design washer have a myriad of design problems and this is only one of them.
Jan 01, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
