Question about LG Battery Bl-44jn Bl44jn For Optimus Black P970
How do I block a number from calling my phone
How block phone numbers that I do not want?
Block an Incoming Call
  • Wait until your phone rings and displays the caller ID information
  • Press the "Block" button on your handset.
  • Press "Menu/Select" or "Block" to confirm your decision.
Block in Standby Mode
  • Press the "MENU" button on your phone's handset.
  • Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
  • Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice.
How Do Block Calls on Uniden DECT 6 0 eHow
May 26, 2016 | Uniden DECT 6.0 Cordless Telephone...
Tip
How to block a Cellphone number?
For privacy reasons, you may want to avoid people knowing what number you are calling from when placing a call from your cell phone. If you want to block your cell phone number from showing up on caller ID when you call someone, the process is very simple. You can block the number through your cellular phone carrier or temporarily on the phone itself..<br /><br />HERE IS THE INSTRUCTIONS :<br /><br /><br /><br /> 1 .Call your cell phone carrier. Dial 611 from your cell phone to reach customer service and tell your provider that you would like to request line block. The representative from your carrier may ask you a few questions, but the process is quick and painless.<br /><br /><br /> 2. Dial *82 if you need to unblock your number. Once you have put line block on your phone, you can temporarily take it off by dialing *82 before dialing out.<br /><br /><br /> 3..Block a specific call. If you do not want to put line block on your cell phone permanently, you can block your number temporarily on a call-by-call basis.<br /><br /><br /> 4..Dial *67 before dialing out to just block that particular call. After entering *67, proceed to dial the rest of the number as usual.<br /><br />
on Apr 10, 2011 | Cell Phones
Have an att z222 want to block one caller how would i do this?
How to Block a Number on Any Phone ' Video ' PCMag.com
www.pcmag.com/article2/0,2817,2476416,00.asp
PC MagazineFeb 11, 2015 - When your phone has buzzed one more time than you can take, you know it's ... AT&T gets very specific when it comes to blocking numbers and wants ... If you want to block callers via T-Mobile's site, you can only do so if you ...
How To Block a Phone Number from Calling your Cell Phone
www.wirefly.com > Wirefly Learn > How To's
WireflyT-Mobile currently does not offer a native way to block numbers from calling or texting your .... Sometimes you can choose the call and one of the options is block caller. .... If you do not have AT&T, there is no way for a carrier to block a number. .... Of course you can block a number from calling your phone, if you don't want to ...
Block calls: ZTE ZMAX ' T-Mobile Support
Dec 25, 2015 | Cell Phones
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
How do i block my phone number when making a call
To block your number for a one time call, dial *67 before calling. To block for every call, you need to call your carrier.
Jun 19, 2011 | Cell Phones
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
How to block a number?
I think you can try an app which name LEO Privacy, when you block a certain call with Harassment interception then you can block it forever. It's very amazing. LEO Privacy Applock Boost Hide Android Apps on Google Play
Jan 14, 2011 | Cell Phones
I don'tknow how to block a contact on a lg arena phone
please follow the steps carefully
  1. Step 1 Call the T-Mobile customer servicemag-glass_10x10.gif phone number located on your phone bill. Tell them you would like to hear about T-Mobile's call blocking service. The customer service then tells you how you can block all the calls coming from your T-Mobile cell phone by adding this service to your plan. When you select this service, anytime you dial a number from your T-Mobile cell phone, the number will come up Restricted on the call receiver's caller ID.
  2. Step 2 Dial *67 prior to any number on your T-Mobile phone that you want to block, if you want to just block one call at a time and choose which numbers you dial are blocked. This is another way you can call someone and to have it appear as a Restricted call on the other end.
  3. Step 3 Program your T-Mobile phone to block all calls to any one individual. Do this by tapping Add a Contact on your T-Mobile phone. Type in the name of the person you want to call. Then tap Add Phone Number. Punch in *67 then the number.
  4. Step 4 Tap the person's name to call him, when you have the person's number programmed into your phone with the *67 first. Every time you tap the person's name, you will be calling him from a blocked number.
hope you dooooo...
please rate me
thank you
Sep 20, 2009 | LG KM900 Arena Cell Phone
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
Jun 30, 2008 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
LG Battery Bl-44jn Bl44jn For Optimus Black P970 Logo
24 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
