Question about Dell Latitude C610 Notebook
FN button function appears to be 'stuck' on
I can't get any keyboard buttons to work unless they have a blue FN function and it is this function that it actions. Previously working fine??? PLease help!! Thanks, Alan
  • 1 more comment
  • mcbridealan Sep 27, 2007
    this problem has developed a little, the FN no longer seems to be a problem but when entering the Windos password, if I press S or A I get 4 stars on the box.
    Also if I leave the keyboard alone the stars begin to appear 4 at a time as if i am pressing something ??? confused?
    any help would be much appreciated, thanks Alan
  • mcbridealan Sep 28, 2007
    removed the 'add on' mouse and all seems to work fine.
    Strange that the mouse upset the machine like that but thanks for you help!
  • Anonymous Mar 22, 2009
    my fn key is always on
Update bios will solve the issue.
Posted on Oct 10, 2007
  • 2,985 Answers
This would appear to the case of the button actuates the FN function is stuck down. Have you tried repeatedly pressing to to free it to try pressing it as if you need FN and perhaps the normal will work -which will then indicate a further line of enquiry
Posted on Sep 27, 2007
  • john ash
    john ash Sep 28, 2007
    This does seem to be a Keyboard or nouse pad stick down.
    It will mean taking the machine apart - are you up to that?
  • john ash
    Aha- you did not say you has bits bolted on
    Makes all the difference
    glad all is well
What is the Fn key for
The Fn key is normally coloured blue. It works in conjunction with the F# keys with blue icons to perform various functions eg. volume control, turn wifi on and off etc.
Apr 06, 2012 | Computers & Internet
Blue function keys
Theres no function key lock, just the blue Fn button on the lower left corner of the keyboard.
If you cant get any of the function keys to work and the keyboard just thinks that you are pressing the standard button without pressing Fn, then this could be a fault with the contacts in the Fn key.
You might want to try
To help you troubleshoot your keyboard. I think you need to get a diagnostic utility running to be sure the key is faulty.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
Laptop types numbers instead of letters
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
Can`t figure out keyboard on acer aspire one, blue numbers and letters etc Karl
blue number etc are functions that are connected to the blue fn button in the left hand corner.
press and hold the blue fn button and at the some time one of the other buttons.
eg volume + or - for volume up and down or the moon shape for hibernate, or the sun to change the screen brightness,antenna button to switch on and of your bluetoot or wifi, or the screen button to switch on and off your external monitor port on the back etc. the blue number are your numeric keypad like on a normal keyboard this can be used in the same way by holding the blue fn button down at the same time.
I hope this was helpful
Dec 12, 2010 | Acer NSK8458AN Keyboard
Key board problem
That is the 'FN' or 'fn' function that is sticking. Check the keyboard for debris. Carefully left the key marked 'fn' with a toothpick and make sure you don't have something stuck under it or use compressed air to blow the keyboard out.
Aug 23, 2009 | ASUS 90-A4C1K1000 Keyboard
How do i access the function keys on the studio 17
I do not use studio but I do use Dell Inspiron.
In order to access the function keys look for a unique button on your keyboard. In my laptop its "Fn" its colored blue and the function buttons are also colored blue(they are underneath some other buttons), so if I want to access the functions button I have to hold the FN button and then press the switch that also has the function button.
For example:
1. the button "Q" has "F1" under it
2. So I have to hold FN and then press Q to access F1
This should be similar to your laptop
Aug 14, 2009 | Dell Studio 17 Notebook
Cat stepped on button a faded my screen how to correct
You'll need a 2 button combination for this fix. All the cat did was adjust the screen brightness. Look at the bottom of your keyboard on the left side for a button that has Fn in light blue -this is the Function key. It controls the other keys that have a second function on them also in blue. On your right side, you'll see keys that look like a sun or lightbulb depending on your model. By holding down the Fn key and tapping either key, you will increase or decrease the brightness of the screen.
Let me know how this works for you and rate this tip accordingly. Thanks for using
Jan 10, 2009 | Dell Latitude D600 Notebook
I cant get the keyboard letters to work that have the blue numbers on them without pushing the fn blue button in the bottom row at the same time
that is how the function keys on some keyboards work. Other keyboards have a key that says Fmode. When this is pressed then the blue keys will work all the time. Other than that the Fn key needs to be pressed at the same time as the function key you are using.
Oct 20, 2008 | Acer Computers & Internet
Keyboard Stuck in Function (Fn) Mode
To unlock number lock (numlk):
Depend on comp, but try pressing (at same time)
fn + f11
fn + Scroll/numlk (next to f12)
f12 + Scroll
f12 + Scroll + fn
ctrl + Shift + Scroll
or in BIOS there is a numlk option
Aug 12, 2008 | Gateway MX6124 Notebook
Dell Latitude C610 Notebook Logo
1,011 people viewed this question
Alun Cox
