Question about Dishwashers
Will not start...all lights come on...model w10438345
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
Start light keeps blinking
More information is needed. What is the make and model number of your dishwasher?
On most models with the digital display: Blinking "Start/Reset" light. This indicates that the dishwasher has been reset and is in the process of turning off. This light will continue to blink for a time period between 75 to 90 seconds depending on the model.
Dec 19, 2013 | Dishwashers
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
I have a bosch washer model wfk2401. i cannot get
door lock mechanism must have jammed in open position. unless the door gets locked, the wash cycle would not start. check the electrical connection in the door lock and physically verify the lock operates when commanded
Mar 19, 2010 | Washing Machines
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Dishwashers Logo
14 people viewed this question
Top Dishwashers Experts
