Question about Kenmore Elite HE4 Electric Dryer
Wil not stay on and no heat.
My electric dryer stopped working the other day. It will only work if i hold the start button in. There is also no heat. It is only a couple of years old. Door switch is okay, I have also tested the Thermal cut off switch and threl fuse for continuity and they test okay. Any other suggestions would be great.
  • 447 Answers
Sounds like the motor
Posted on Sep 28, 2007
Dryer wont stay turned on. As soon a you let go of the start button it stops
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | Kenmore 62602 Electric Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Start button and no heat
Those two problems are usually unrelated and I believe you just have a coincidence that they both happened at the same time. You should replace the start button since it is faulty. The heating problem could merely be that the machine does not have enough time running to heat up since you have to hold the button to keep it running, however if that is not the case then you should replace the heating element and the thermostat. Possibly the thermal fuse as well just in case.
Dec 24, 2009 | Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer help
ther run winding of the motor is not working replace the motor it is staying in the start winding
May 06, 2008 | Kenmore 62602 Electric Dryer
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Kenmore Elite HE4 Electric Dryer Logo
65 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
