Question about Broan-NuTone Broan Elite E661 Under-the-Cabinet Range Hood
The broan hood vent light switch blinks even when off
  • 4102 Answers
SOURCE: Replace Broan Model K260A Range Hood Light Switch Slider Assembly
Hi if the new part has no screw holes or place for clip and it is only push in connector ie you dont need to solder the wires to it then it will just pull out use a small screw driver under the edge and gently pry free you cant damage it anymore than it is anyway can you.
Also on the side of the new switch if their is no groove cut into it for a push on clip to hold it in place then it will just pull out and push the new one in.
Posted on Jan 30, 2008
SOURCE: Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Posted on Jun 28, 2008
dmftrucker
  • 1922 Answers
SOURCE: short in electrical line or switch on cooktop hood
its the variable fan circuitry, the triac semiconductor is shorted
Posted on Nov 04, 2009
SOURCE: Broan Allure QS3 push button switches for lights not working
you need a new set of controls,
Posted on Feb 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: are the rangemaster light lenses the same for all of his hoods
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
Jan 30, 2008 | Broan-NuTone Broan Range Hood Accessory
Why does my Broan Range Hood exhaust fan switch keep blinking?
is it on sleep mode...then it should switch off after sometime...try it
Jul 26, 2014 | Broan-NuTone Kitchen Ranges
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Jun 22, 2014 | Broan-NuTone Broan Elite E661...
Lights on hood fan will not shut off.
It sounds like your switch is getting stuck internally. It most likely needs to be replaced.
Here is a break down of your unit. http://parts.broan-nutone.com/broan/Shop?DSP=30200&PCR=1:1000&IID=QS330AA&imagesequence=
Also, you can order parts directly from Broan, here. http://parts.broan-nutone.com/broan/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=QS330AA
Hope this helps you somewhat, please post back if you need more help.
Mar 07, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Range vent damper noise
Check to make sure that the installer completely untaped the damper when he installed it. It needs to be able to move freely.
Apr 04, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Kitchen Ranges Logo
44 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
