Question about Foxconn Computers & Internet
Floppy boot disk
N15235 MB does not recognize unix floppy boot as bootable.
    Problem Solver:
  • 16 Answers
Try setting the boot order in the BIOS to floppy drive first. If that does not work, try writing the floppy again, preferably to a different, new floppy disc in case that one is failing.
Posted on Oct 21, 2013
4 Suggested Answers
ohms
  • 1879 Answers
SOURCE: New ECS G31T-M won't recognize IDE devices
Locate the boot options in your BIOS and set it to boot from the Hard Drive
Posted on Oct 13, 2008
marketex
  • 371 Answers
SOURCE: my computer hangs when i boot it by any bootable cd or floppy
Apparently you solved your problem and the system no longer hangs, though you never supplied the information requested.
Posted on Apr 18, 2009
  • 1027 Answers
SOURCE: I have a PM8PM motherboard and I want to boot up
Check the BIOS settings again - there should be a boot sequence selection.
Posted on Apr 15, 2010
Unix floppy boot disk
  1. Make sure the floppy drive is connected to the motherboard.
  2. Set Floppy as boot in bootmenu
Oct 21, 2013 | Foxconn Computers & Internet
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
Computer won't boot error code sata disk s/n 0F00-136B and many more???
looks like hardware failure.
find out what harddisk exactly you do have in the bios :
- press Del or F1 or F2 during booting, goto IDE devices, look for the model, size (in GB) etc.,
write down (the manufacturer could be: samsung, seagate, maxtor, fujitsu...)
- then change order of boot devices so that cd/dvd-rom drive and /or 3,5 '' floppy drive boots
before the harddisk, exit saving changes (F10 or Esc)
- then get diagnosis program from the harddisk manufacturer's homepage,
copy that to a bootable floppy disk or burn it to a cd-r/cd-rw which must be bootable
- boot from the cd or floppy, run diagnosis tool, both short and long test, what does it say then?
- if hardformat is available, perform one
- might work now, at least the hd will be recognized
-setup new windows installation.
have fun
Source : STAT DISK S/N 0F00-136B
Aug 16, 2012 | Dell Computers & Internet
Hi, I have a Gateway GP6-566C SE. I am trying to have it read a bootable CD but it doesn't seem to recognize the CD on a bootup. Looking at the bios I can see that the CD is supposed to check the CD...
Most desktops will check the floppy drive when starting up anyway regardless of what setting is in the bios, try to look for any commands required for boot selection when you boot up...I have to hit TAB while booting up to select to boot from CD.
Let me know how you get on
Mar 21, 2011 | Gateway GP PC Desktop
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Yea sorry, forgot that tid-bit of info. It,s the W3118 eMachine / Gateway FIC K8MC51G
This issue can be caused by any of the below reasons.
-Corrupt boot files on the computer.
-Settings for hard disk drive are not correct.
-Floppy diskette or CD in computer causing issue.
-Boot devices not set properly.
-BIOS corrupt or misc. setting not set properly.
-Connections loose or disconnected.
-Bad Hard disk drive or other bad hardware.
Solution:
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
Once at the A:\> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:\> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue attempt to reset the BIOS / CMOS settings to the factory or default settings.
If the computer has been recently moved or new hardware has been installed in the computer it is possible that a connection may be loose or even disconnected. Verify that the hard disk drive, floppy and CD-ROM cables are properly connected.
Bad hard disk drive or other bad hardware
If you computer continues to freeze at the DMI message after attempting all of the above recommendations it is possible that the computer may be freezing because of a bad hard disk drive or other bad hardware in the computer.
Before replacing any hardware we first recommend you attempt to erase everything on the hard drive and start over.
If you're unable to get to the point of re-installing the operating system it's likely your computer has a hardware issue and it's suggested that the hard drive be replaced. If that doesn't resolve the issue then have the motherboard replaced.
Oct 20, 2009 | E-Machines eMachines Desktop PC
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
Jul 31, 2009 | Acer Aspire 5610-4648 Notebook
Acer 3050 won't boot. Disk Read Error
have fun
Apr 21, 2009 | Computers & Internet
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Strating up problem
    Please update MB with the latest bios version:
    http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Bios&MenuID=1&LanID=9
    Flash from a floppy disk. Re check bios after flash. Go to Boot section. Make sure you have the correct drive listed in the boot order. If trouble still continues. Go to the serial ATA SATA hard drive's manufactures site. Download the tools/utilities & set the drive up with their bootable floppy disk software.
    (Do this without the IDE connected to the system). Try installing windows. You shouldn't have a problem. (The bootable floppy can also test the drive).
    Luck!
    If problem returns, please include detailed results.
    Mike
    Jun 03, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
    Computers & Internet Logo
    Top Foxconn Computers & Internet Experts
    David
    David
    Gareth Cockram
    Gareth Cockram
    Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
