Question about Ameritron Arb-704 - Amplifier Transceiver Keying Interfaces
How to connect Ameritron ALS-1300 and Icom 706
706 mk 2 shutting down on fm high power
sounds like voltage drop. check that your power supply isn't dropping in voltage when transmitting. FM draws a large amount of current all the time, and not just on peaks. The 706 will shut down if the voltage at the radio drops to about 11 volts
Feb 05, 2014 | Icom Radio Communications
How to connect sb-200 to ic-7600
you really need a amp keyer interface, these new radios are voltage sensitive, I use ameritrons http://www.ameritron.com/Product.php?productid=ARB-704
Nov 19, 2013 | Icom Ic-A110 - VHF Air Band Transceiver...
My icom 706 will not transmit on HF but ok on vhf
Puts out about 5 watts on all bands into a "Dummy Load"
Sep 08, 2013 | Icom IC-706MKIIG
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
How can i do a factory reset on an icom ic-706, basically i want to clean it all off and have it like it came out the factory, it this possible??
Hi Paul,
The best I can come up with is Try this: join yahoo group Specific to your radio Make/Model, the experts there will help you with useful info and you can download manuals, schematics and software, if available, for your radio and all this is free.
I hope I have been of assistance to you.
Regards,
Peter
Nov 29, 2012 | ICOM Informatique Icom IC-F21 16ch UHF...
How to connect a Yaesu FT990 to a Ameritron AL80A Amp
Instruction on page 9
Yaesu FT990
Use "RLY" terminal as an input for triggering the
Ameritron AL80A Amp
Sep 19, 2012 | Radio Communications
Ameritron Arb-704 - Amplifier Transceiver Keying Interfaces Logo
302 people viewed this question
Top Ameritron Garden Experts
Dennis Key
Dennis Key
john h
Are you an Ameritron Garden Expert? Answer questions, earn points and help others
