Question about Wildon Home Dana 50" TV Stand Finish: Black
Assembly instructions for wildon home Dana 50" tv stand
I need to speak with someone at Wildon Home customer service
get the manufacturers/ retailers home page up and call the listed phone number yourself
Jan 09, 2017 | Cell Phones
I need a detailed schematic of the front axle of my 2002 F250 4x4
www2.dana.com/pdf/5326.pdf
I believe you have a Dana 50 front axle. 2004 and up come with Dana 60. You can upgrade to the Dana 60 as a drop in.
http://www.ford-trucks.com/forums/1059204-dana-50-parts-breakdown.html
Nov 14, 2015 | 2002 Ford F250 Super Duty SuperCab
How do I get assembly instructions for Wildon Home Corvallis Trimline Full Size Futon Frame?
You can contact factory direct or place you purchased from. Contact Us: 877-WAYFAIR (877-929-3247). I know the item is from Vietnam and instructions are not the best.i would lay out all your screws by size. Connect your back board to both end pieces withe the medium size screws. Then mount front board with long screws should be 4 for each side. Then assemble the couch lay down parts place on your assembled base. Uses washers on the long screws as this section swivels up and down. This reduces friction between the wooden parts. I hope this helps. Send your photos to mddoc13atyahhoodotcom. I will try to quite you. Attention Bob
Feb 01, 2015 | Wildon Home Corvallis Trimline Futon Frame...
What are the colors this set is available in?
This set is available in a wide variety of colors:
Feb 16, 2014 | Wildon Home Regency Havana 300 Thread...
Mount screw size
According to the manual, available from the LG web site, you'll need:
Screws for stand assembly
(Refer to P.13, 14)
4ea. M4x26 and 3ea. M5x14.5
http://www.lg.com/us/support/software-manuals#
Dec 29, 2013 | LG 50PT350 50 in. Plasma TV
Room essentials tv stand assembly instructions
i need assembly instructions for RE tv stand number 12185594 my email is mcfporras@hotmail.com
Mar 15, 2013 | Sauder TV Stand: Room Essentials Dark...
Bought a 50 philips (50pfp5332d/37). went to assemble on the stand and their were no screws. Called philips and they sent me a bag of screws that don't fit. I called again and they have no other screws...
Take the tv off the stand and lean it against soemthing, take the stand to a hardware shop and find some bolts that match the threads inside the stand. I think that would be your best bet. Just dont lay the tv down, if you have ot put it in the box thats ok, I just dont want it to get broken while we hunt down some screws.
Dec 12, 2008 | Philips 50PFP5332D 50 in. Plasma...
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Wildon Home Dana 50" TV Stand Finish: Black Logo
43 people viewed this question
Top Wildon Home Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Wildon Home Furniture Expert? Answer questions, earn points and help others
