Question about Ovens
Kenmore elite c970-440984
Oven temp does not cut out as set. unit has to be turned off when temp reached
  • 3 Answers
SOURCE: F5 error on a Kenmore Gas Oven
f5 is a door lock code there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Posted on Apr 01, 2007
SOURCE: kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Posted on Jul 20, 2008
  • 139 Answers
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Posted on Aug 28, 2008
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
SolutionGuy
  • 331 Answers
SOURCE: GE JKP26G Electric Oven Doesn't Maintain Temperature
Diagnosis= failed thermister (temp probe inside the oven cavity) The part number is WB23X5340 and it lists for ~$72.00 at your local appliance parts place.
Bad news is that you have to pull the oven out of the wall to do this repair.
Good news is that it's not difficult to do.
TURN THE POWER OFF AT THE BREAKER BEFORE YOU PROCEED! Otherwise you'd look like this...
Ready? OK!
All you need is;
1.) Phillips screwdriver
2.) 1/4" socket/nutdriver
3.) Ratchet if you don't have a nut driver
4.) 36 quart Igloo ice cooler (like what you'd take to the lake or the beach)
5.) Sturdy wire (smaller than a coat hanger, preferably)
6.) Flashlight
Did I mention TURN THE POWER OFF AT THE BREAKER BOX?
Now we're ready for surgery.
Open the oven door and look where the oven meets the wood. You'll see a couple of screws there... remove them. Now the oven is ready to pull.
Place your Igloo cooler under the oven. Slowly pull the oven from the cavity until you have it out and sitting on the cooler. (don't sweat it... the oven is light. maybe 75 pounds or so.)
Now that you have it out, open the oven door and remove the oven racks. Look inside (may need a flashlight) and locate the temp probe, there are 2 screws holding it in place. Remove those 2 screws and set them inside the oven cavity, you'll need them soon.
Now go to the back of the oven (slide it if necessary) and remove the back panel. (*Here's a tip... some of these GE units? All you have to do is remove one screw to access the temp probe, so look carefully... don't go nuts here. Sometimes the whole panel/panels DON'T have to come off)
You'll see the temp probe wires... they are 2 small white thermally insulated wires coming from the cavity to the wire harness in the back. Disconnect this harness and pull the old probe out from the front of the oven cavity.
OK... now to get the new probe installed... See that plastic thing on the end of the new probe? It's a pain to get through the cavity where you'll be plugging it into. It's best to have help. but it can be done alone (I've never had help, it's just harder)
Take the sturdy wire (from the tools list) and make a small hook at the end of it. Poke it through the hole that the old probe was stuck through. Now hook your new probe into the hook. Now go to the rear of the oven and gently (did I say gently?) pull it through to the back of the oven.
Now that you have it through, connect it to the harness. Now all you have to do is reinstall the rear panel/s and the oven. No biggy. Just take care not to scratch your wood trim... line it up before lifting and installing.
All in all about an hour's worth of work. I know it sounds like alot more but I could have done this in less time than it took me to type it.
Congrat's on your first major oven fix! Let us know how it turned out.
Posted on Mar 17, 2009
I have a Kenmore Elite oven. The upper oven doesn't maintain temp setting. Eg, if I set baking temp at 375, oven may get to that temp but a few minutes later, it's at 325 or less. Broiler works fine.
im taking that it,s gas....do you smell gas at anytime? sounds like you migh have a light gas leak if it,s gas...also how old is this oven?
Aug 13, 2016 | Kenmore Ovens
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore electric oven
Dec 02, 2007 | Ovens
Mar 31, 2007 | Kenmore 30169 Electric Single Oven
Ovens Logo
101 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
