Question about Xerox CopyCentre C128 Black and White Copier
Program copier not to sleep at work
The copier goes into sleep mode and want to program it to be awake from 7:30am till 5pm. It is a Xerox CopyCentre C55
    Novelist:
  • 208 Answers
  1. Press the [Access A] (key symbol) button on the top, right corner of the Control Panel.
  2. Enter the system password using the numeric keypad, then select [Enter] on the Touch Screen. The default password is 1111.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. To cancel the operation, select [Cancel]. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
  3. If the Internal Auditron is not enabled, select the [Go To Tools] button (does not apply to copier-only models). If the Internal Auditron is enabled, select the [Tools Pathway] button.
  4. Select the [More] button.
  5. Select the [Power Saver Administration] button.
  6. Select the [Set Duration Times] button.
  7. To adjust the 'From Standby Mode to Low Power Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Standby to Low Power may be set between 1 - 120 minutes.
  8. To adjust the 'From Low Power Mode to Sleep Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Low Power to Sleep may be set between 0 - 120 minutes.
    NOTE: There should be a minimum of one minute between the 'From Standby Mode to Low Power Mode' and 'From Low Power Mode to Sleep Mode' settings. For example, if the 'From Standby Mode to Low Power Mode' is set to 10 minutes, then the 'Low Power Mode to Standby Mode' should at least be set to 11 minutes.
  9. Select the [Save] button.
  10. Select the [Exit Tools] button.
Posted on Nov 30, 2007
  • 363 Answers
I suspect it goes to sleep after a period of inactivity. To wake it up just use it. You dont want the heated rollers to be heated all the time, it wastes electricity. I'm not sure if this copier can be programmed to be awake as soon as you start work. The most environmentally friendly option would be to turn it off when you leave work and turn it on again just before it is next needed. If you think there is a better answer then PLEASE just rate me with 'Thanks for trying' Regards
Posted on Sep 27, 2007
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
How do I do a password for the machine Xerox CopyCentre C128
Click on the link below and select to view the Xerox CopyCentre C128 owners manualm inside the manual will show you how to set the password
http://www.support.xerox.com/support/copycentre-c123-c128/documentation/enus.html
Dec 19, 2010 | Xerox CopyCentre C128 Black and White...
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Oct 03, 2010 | Xerox Phaser 8560MFP Laser Printer
CopyCentre C123 Copier Copier: CODE 116-331...
It may be a defective Main System Controller board 160K91660 or Hard Drive 960K01120.
There is a diagnostic which requires the Xerox Technician's Laptop to test the Hard Drive.
You might get lucky just reseating the Hard Drive.
Whit
Item, Inc.
May 17, 2010 | Xerox CopyCentre C123 Copier Copier
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
XEROX COPYCENTRE C20
u can find manual for this copier at the link below:
www.lostmydrivers.com
Jan 10, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C128 Black and White Copier Logo
314 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Clive
Clive
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
