Question about Canon PIXMA MP170 All-In-One InkJet Printer
Error 5100 does any one know how to solve this problem thanks
  • 4 more comments
  • Anonymous Feb 28, 2008
    Getting same error message , paper is jamming?? Fairly new, purchased few months back!
  • catie739 Mar 28, 2008
    when trying to print ERROR 5100 appears and suggests I try the User Guide (I cant find it) can anyone help its very important
  • Anonymous May 29, 2008
    error 5100 cancel printing turned printer off and still the message flashing
  • honey_hlew Aug 08, 2008
    haven't use printer for a while. Then when I trying to scan it. It's wont let me and error message blinking "check printer 5100"
  • Anonymous Feb 23, 2009
    al entrar el papel se va de lado y solo corre el rodillo de la derecha lo cual hace que el papel entre de un lado y el otro se quede aciendolo jirar y tascar
    que puedo hacer
  • Anonymous Mar 05, 2009
    aparece compruebe impresora error 5100
Service Error 5100 is Displayed
Cause
Action
Movement of the FINE Cartridge Holder is blocked.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Posted on Apr 19, 2008
Error code 5100 on cannon pixma mp460 Does not load paper
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve this error follow the given steps:-
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed.
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
Sep 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
New printer canon pixma mx360....... when i pushed the botton on it says printer error has occurred 5100
Actually the printer is not actually loading the cartridge and showing you the Error 5100.
First of all turn off printer
then remove both the cartridges from the printer.Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches. After it return the cartridges and turn on the printer.Error will be automatically remove
Jul 18, 2011 | Canon Pixma MX360 Printer
States error 5100 on our canon i80 printer
  • Turn off printer
May 15, 2011 | Canon i80 InkJet Printer
5100 error message
Error 5100 means that the cartridge can not be detected by the printer
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Canon PIXMA MP540 All-In-One InkJet...
I am getting an error 5100 message. On the printer it says cartridge jammed thanks
Hello and WelcomeError 5100 means that the cartridge can not be detected by the printer.
  1. Turn off printer
If it is HELPFUL, Please Rate it as Four Thumbs THANKS
Mar 08, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100 on Canon IP 2770
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My Pixma ip1980 service error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Aug 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error 5100 canon mp470
Service error 5100 is displayed
Cause: Movement of the Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
With power off, move the cartridge holders manually
reseat the cartridges. Then power back on.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 10, 2009 | Canon Office Equipment & Supplies
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Solve error 5100.cannon pixma 145 error always out # 5100
5100 error is a carriage error. Could be caused by the carriage unit, timing strip, logic board or carriage motor. Check that nothing is obstructing the carriage from moving freely and that the clear timing strip is ok.
Nov 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
767 people viewed this question
old marine
old marine
