Question about New World 60ECHDGm Electric Kitchen Range
All four hob rings only work at full power cannot turn them down to simmer
I have a problem with my Beko BDVC667W hob of my cooker.
will the control knnob turn it totally off. possibly the plastic part need replaced
Jan 22, 2015 | Kitchen Ranges
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Zanussi hob can't turn off full power on one ring
the regulator is faulty you will have to fit a new one fairly easy task let me know if you want more help
Apr 17, 2012 | Zanussi Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
I can't get a low flame on my lpg hob. The flame isn't outrageously huge so I think the hob is converted for lpg. But I can never get anything on a simmer, even with simmer mats over the flames. ...
If you remove control knobs you should find a hole where screwdriver can be inserted to adjust the flame failing this ensure correct injectors were installed when converted to lpg
Jul 13, 2009 | Ovens
Neff T1722SO Ceramic Hob - rings don't heat
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Mar 08, 2009 | Neff Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
New World 60ECHDGm Electric Kitchen Range Logo
Top New World Kitchen Ranges Experts
ashburton
Ismael Rodriguez...
Paul Carew
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
