Question about Brute 7800802 22-Inch 190cc Briggs & Stratton 675 Series Gas Powered FWD Self Propelled Lawn Mower With High Rear Wheels
Traction control cable is unattached at front wheel
  • Ronny Hill
    Ronny Hill Oct 22, 2013
    the traction control cable on a murray brute lawnmower runs from the top pushbar to the left front wheel. The cable end attaches. to the pully system to engage the wheels when the top lever is squeased. I need a picture to see where to reconnect the cable end to the pully system. Right now my wheels do not turn since the cable is unattached.
Why does my 4 wheel drive not work all the time?
Elaine,
not work, do tell what makes you think it dont work (a lamp) or tires slipping or dead tires. (by tires mean that and traction)??????????
what mode fails, of the many, and where.???????
first off, we dont know what your tires are touching.
on road, or off road. pavement or ICE or snow.
that matters big time . (you read manual and match MODE to Road)
your lost operators guide explains all that, right?
eg: how and when to use, 4wd, its all there. I promise.
ControlTrac 4-wheel-drive system
here are the mode. which one , gives you problems.
quote ford with comments.
What are the modes, and how do they differ?
(note this is the operational behavior of a 2008 Ford Expedition. Newer and older Expeditions will vary only slightly)
2H 2-wheel-drive with high range gearing (1.00:1) Rear-wheel-drive capability,
2-wheel electronic traction control system is enabled
4A 4-wheel-drive Auto with high range gearing (1.00:1) Full-time all-wheel-drive capability, ((best on pavement or any time)
Electronically adjusted torque split to front & rear wheels, Electronically variable center differential,
Front driveshaft & rear primary driveshaft allowed rotational speed difference,
4-wheel electronic traction control system is enabled
4H 4-wheel-drive with high range gearing (1.00:1) Part-time 4-wheel-drive capability, (not for dry pavement EVER)
Continuous 50/50 torque split to front & rear wheels, Electronically locked center differential,
Front driveshaft & rear primary driveshaft mechanically locked with no rotational speed difference,
4L 4-wheel-drive with low range gearing (2.64:1) Part-time 4-wheel-drive capability, (off road usage, mostly)
4-wheel electronic traction control system is enabled, ESC and RSC are disabled
In 4A mode the center differential is electronically-controlled and rear drive wheel bias. The on-board computer monitors for any sign of rear drive wheel slip (loss of traction)
If loss of traction is detected, the center differential is told to send a share of the engine\'s torque to the front drive wheels. It will not let the front driveshaft turn at the same speed as the rear driveshaft.
What about traction management?
1997-2002 model Ford Expeditions offered an optional limited-slip rear differential (LSD). A conventional open rear differential was standard along with the conventional open front differential and the electronic locking center differential.
comment with out LSD, one tire can spin, on say ice.
but the other 3 tires dont, in full time.
Jul 04, 2014 | 2003 Ford Expedition
Batery removal
Under the hood just unattache the battery cables if not under the hood look in your trunk
Dec 23, 2012 | 1997 Chrysler Sebring
The traction control light comes on and then the engine loses power, just after I start it. What can I do about it.
These trucks are known to have problems with the front wheel speed sensors that control your 'traction control'. The traction control is actually applying your brakes. Thats why when you turn it off, You can move with no problems. The only way to really know this for sure is to take it to a repair shop and have them diagnose the problem. You can always just replace the front wheel bearing assemblies (they have the wheel speed sensors built in), but that can get pricey.
Aug 16, 2012 | 2003 GMC Yukon
ABS light is on all the time as well as Traction Control light. Grinding occurs while driving
with traction control set up cars abs and tranction control sensors are in the wheel bearings when a wheel bearing goes out grinding will come from front wheels and will ruin abs and traction control sensors causing the malfunction. Most likely by your description this will be it.
Mar 18, 2010 | 1996 Chrysler LHS
Traction light stays on as well as my abs would come on and stays on and clicking noise during braking.
Sounds like you have a problem in the front brakes or a front wheel speed sensor. A common cause for a Traction light is a faulty front ABS wheel speed sensor or harness. When the Anti lock brake computer sees a problem in the ABS syetm, it disables traction control as well.
Mar 12, 2009 | 2003 Oldsmobile Silhouette
1996 Lincoln Town Car traction control braking front wheels?
Your traction control comes on when it notices either your rear tires slipping or front tires slipping and it counteracts the slip to control the slide. It should be working all 4 brakes though not just the front. There is a traction control sending unit under the dash that should be looked at to make sure that it is sending the Trac Control the right message. If it is reading the slide wrong then it should be replaced. Sometimes then can just reset the computer and all works well other times you need to replace the sensor. I would see if they can reset the computer first then go from there. Pleae rate if satisfied. Thank you
Feb 12, 2009 | 1996 Lincoln Town Car
07 Ford Traction Control
2 wheel drive refers to the rear wheels.
The traction control feature applies the brakes to the wheels that are spinning due to lack of traction so that they can slow down and get a grip or traction, if its in 2 wheel drive the system will pulse the brakes and you will hear and feel the system engage usually a buzzing vibration and an indicator light will come on the dash to tell you its engaged
Dec 28, 2008 | 2006 Ford Explorer
2001 impala abs brakes light comes on only when you go thru water
The traction control system uses the abs wheel sensors to detect wheel speed if the abs light is on the entire abs system will disable giving you regular braking but it will also stop feeding info to the traction control
Dec 04, 2008 | 2002 Chevrolet Impala
TRACTION CONTROL.
that is what it is desgined to do - reduce acceleration and apply the brakes intermittently when the wheels spin. You have a switch you cn push to disable it. You need to disable each time you start car. See owner manual.
06-10: Traction Control 1996 Contour, Mystique Workshop Manual
DESCRIPTION AND OPERATION Traction Control System The optional traction control system is designed to control wheel spin when accelerating on slippery or loose surfaces. Traction control system is available only with anti-lock brakes. The traction control system includes the following components:
  • Hydraulic control unit.
  • Throttle control actuator (9N825).
  • Traction control switch.
  • Traction control warning indicator.
  • Front brake anti-lock sensor (2C204).
  • Rear brake anti-lock sensor (2C190).
The traction control system operates as follows:
  • System functions by transferring torque from the spinning wheel to the wheel with the most traction.
  • This is achieved by applying the brake at the spinning wheel through the hydraulic control unit or reducing the throttle opening.
  • Traction control braking and throttle control occur at vehicle speeds up to 50 km/h (30 mph).
  • At vehicle speeds above 50 km/h (30 mph), only throttle limiting control is used.
  • If speed control is operating when traction control system engages the traction control system will disengage speed control through the use of a speed control relay. This action is the same as applying the brake pedal with speed control engaged.
1996 contour
Traction Control Switch The traction control switch is located on the instrument panel, left of the steering column.
Oct 22, 2008 | 1995 Ford Contour
2001 olds ABS and traction control sensor issue
An ABS sensor DOES affect the traction control system. Traction control uses these sensors to determine if a wheel is losing traction. A bad sensor will cause both the ABS and TRACTION lights to come on.
The CHECK ENGINE light however is going to be a seperate problem.
Jun 08, 2008 | 1999 Mazda Pickup
Brute 7800802 22-Inch 190cc Briggs & Stratton 675 Series Gas Powered FWD Self Propelled Lawn Mower With High Rear Wheels Logo
Top Brute Garden Experts
Vernon Taylor
Jesse Walters
Jesse Walters
Andrew Taylor
Andrew Taylor
Are you a Brute Garden Expert? Answer questions, earn points and help others
