Question about Yamaha RXV467 Receiver
How to program codes for yamaha RAV334 remote
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
How do i program a yamaha rav150 remote
You do not say whether your remote is universal but if it is, you can use code search to find codes for both devices. if a search through all codes stored in the remote is unsuccessful, you may have to try another universal remote. All universal remotes do not store all possible codes.
Jun 21, 2016 | Yamaha Remote Control RAV150 p/n:VZ338300
How to code yamaha rx-v665 into directv remote
Go to the Directv Remote programming Page and enter your device
It will give you the correct codes or a universal code for your brand receiver.
Oct 02, 2014 | Yamaha RX-V663 Receiver
Is it possible to program an alternate remote to replace the Yamaha GX-50 OEM remote VU506200.
You could pick up a new one at this website for $40. Not sure if that is feasible.
YAMAHA GX 50 AUDIO REMOTE CONTROL SYS1 VU506200
I believe the ZA11360 remote works with Amplifiers and is not compatible with the GX-50 mini sound systems. You could try and buy a universal remote and then try and program it for the GX-50 but it is hard to find codes. There are a few Yamaha sound system codes available on the web and you could try these with the ZA11360. But these are for Yamaha CD players. Try one of 60036, 60490,61907.
Aug 03, 2014 | Yamaha Remote Control VU506200...
Codes to program a yamaha remote rav283
This remote was sold with the HTR-6130 reeciver(among others.) The HTR-6130 manual contains instructions and programming codes. You can download the manual here: http://static.highspeedbackbone.net/pdf/Yamaha-HTR-6130BL-Manual.pdf
Dec 09, 2009 | Yamaha Televison & Video
I would like to operate a Samsung HD Cable receiver (DCB-H360R) by means of a Yamaha remote control (RAV293). I have tried all Samsung remote control codes as specifid in the Yamaha Owner Manual, but no...
Yamaha remote supports only those codes that are in the manual (they are pre-programmed in the remote), so no other code can be used. Your only option is to try codes from different brand in the manual (if not done already) or buy a universal remote, which you can program both for Samsung and Yamaha.
Nov 28, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
We have just inherited a Yamaha RV-X592 Audio Receiver and have tried all the remote codes listed with the universal remote that we purchased. I have found two listed codes that turn the reciver off, but...
You need a learning remote or a "Logitech Harmony" or a "Universal Remote Control" (Brand name) Yamaha uses "Discrete Power Commands"
You will not find those in any remote under $70 or $80.00
If you don't want to spend the money, program the Yamaha's Remote to control your devices. It will control all features and functions, it will just take some time to program. Hope this helps
Sep 26, 2009 | Yamaha RX-V592 5.1 Channels Receiver
How do i program for sony cd player
I also have a Sony CD player (CDP-XE330) and I have tried almost every code from the yamaha manual, but without success.
The only codes that yamaha remote supports, are the codes from the list in the yamaha manual. If none works, you are out of luck and the only solution is using the original sony remote (if you have one) or universal remote.
I have recently purchased Logitech Harmony 525 on eBay and now I control all my 7 devices with it without any issues. It is programmed via USB and Logitech has codes for almost 250.000 devices.
Sep 16, 2009 | Yamaha RX-V361 Home Theater Receiver
Scientific Atlanta 8300hdc remote program instructions
Don't know the exact code for your STB, but you can download the manual from http://www.yamaha.com/yec/products/productdetail.html?CNTID=5027893&CTID=5000300&RLTID=1505&DETYP=RELATION ,
There you can find the list of all codes and also how to program them into the remote.
Apr 09, 2009 | Yamakawa DVD-218 DVD Player
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Yamaha RXV467 Receiver Logo
114 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
