Question about Fujitsu (MJA2250BH-G2) SATA Hard Drive
FirmwareFujitsu (MJA2250BH-G2) SATA Hard Drive
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: where can i download driver for fujitsu mja2250bh g2 sata hard drive
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)dont use numbers and / - you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
hope it helps
Posted on Apr 16, 2012
kaptan_1881
I am looking for just where is the problem. I was try 2 diffrent pc but in the Bois does not showing my hdd. I was delete with maxtor program and than its never work again. Is there any solution for this hdd? I wonder its hardware problem or software problem?
Posted on Jan 25, 2014
Fujitsu (MJA2250BH-G2) SATA Hard Drive problem
replace the logic card with same hard disk drive.
Jan 25, 2014 | Fujitsu (MJA2250BH-G2) SATA Hard Drive
Where can i download driver for fujitsu mja2250bh g2 sata hard drive
also
hope it helps
Apr 15, 2012 | Fujitsu Computers & Internet
Windows 7 do not reconize hard drive
Check the Drive Partition in Disk Management
Even though the drive may not be visible on the Desktop or in My Computer check to see if the drive is recognized in Disk Management
Right click on My Computer and select Manage from the menu From the Computer Management window select Disk Management from the menu on the left
In Disk Management check to see if the drive is visible
If the drive is found look at the partition for the drive
New drives will be labelled as FAT32 and have a drive letter assigned
If the drive does not display as Healthy or shows the file format as RAW then the partition has become corrupt
It could also be corrupt if the bar above the drive is black and shows as Unallocated
To make the drive usable again after a partition has become corrupt or lost start by right clicking on the drive in Disk Management and select Delete partition from the menu
Then right click on the drive again and select create partition from the menu
Follow the steps in the partition wizard to create a Primary partition
NOTE: Deleting the partition will cause all data on the drive to be lost. If the partition has become corrupt this may be unavoidable
Hitachi Global Storage Technologies is not responsible for lost data
It is highly recommended that data be backed up in multiple locations on multiple drives to minimize data loss
After the new primary partition has been created Disk Management will display the drive with an NTFS partition
The NTFS partition is unusable on a Mac. If the drive is used on Macintosh and Windows computers follow the link below to obtain a FAT32 formatting tool which will allow both Windows and Macintosh users to use the drive
hope it helps
Apr 15, 2012 | Fujitsu (MJA2250BH-G2) SATA Hard Drive
Fujistu MJA2250BH Spinning but won't mount
Hard to say what the problem may be with out more information.
You may ask the guys at http://FreeDataRecovery.us to look at it for you.
Feb 10, 2012 | Computers & Internet
FUJITSU MJA2500BH G2 ATA Device driver
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 31, 2011 | Fujitsu (MJA2500BH-G2) 500 GB SATA Hard...
I have a 3 SuperMicro P4DP8-G2 motherboards that have no video at start up and do 2 types of beeps after a few min. 1 long beep with short beeps continuously. and the other is 2 long beeps continuously....
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 28, 2011 | SuperMicro SUPER DP8-G2 (P4DP8-G2)...
My Fujitsu MHZ2080BH G2 Hard Drive Froze Up and when I rebooted it reported that the hard drive was not found. I ordered an exact replacement drive and tried to pirate the circuit board from the new drive...
With the new controller card attached to the old drive, try to attach the hard drive to another computer via a EIDE/SATA to USB adapter, this way the other computer will read the drive as an external. Now open up Administrator tools in the control panel and click on computer management, then click on disc management. All drives attached to the computer will show here, whether they are active or not. Now find your drive, it will probably show up in the lower column with a drive number but no letter. Right click in the square where it says drive is "offline" click on initialize drive, follow the prompts and click on what ever it suggests. If it goes through the drive is initialized, if it comes up and says "drive not ready", then it means the control card swap sis not work and the drive is a complete loss. Your only option at that point is data recovery in a "clean room" facility.
Jan 07, 2010 | Fujitsu MHT2080AH 80 GB Hard Drive
When doing new installation i can not find hand disk drives
Check your BIOS if it's detect your Hard Drive.If detected then check your system BIOS whether SATA setting is enable or not. Disable it if you have enable it in IDE configuration.If you find there is no way to configure SATA in your BIOS setting then you need to download SATA driver for that Hard drive and used a software called nlite.
Here is the link for nlite software
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
Here is the guide link for using nlite software to make a bootable OS cd with SATA driver pre-installed.
http://www.nliteos.com/guide/index.html
Here is the link for SATA driver for your ProLiant ML150 G2 Server from HP.
ftp://ftp.hp.com/pub/products/servers/supportsoftware/ZIP/HP6-port_SATA_RAID_Controller_Driver_for_Windows_v4.2.1.7365.zip
For more information on how to installed and configured check the link below
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=435422&taskId=115
the above procedure is for Windows based Server Operating System.If you are planning for Linux based then download the drivers by selecting the operating system from the link given below
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279685&lang=en&cc=us&prodTypeId=15351&prodSeriesId=435422&taskId=135
Dec 23, 2009 | HP ProLiant ML150 G2 Server
Fujitsu (MJA2250BH-G2) SATA Hard Drive Logo
37 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
