Question about Electrical Supplies
I have a Kohler Confidant 5, model 5ckm61 generator in my RV, serial # 338225, spec# 101218. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depressed . Have checked the oil pressure switch and working correctly . The motor runs fine if I disconnect the throttle solenoid and work the throtttle manually , so is not a engine problem . It has to be something that in circuit board that controls the throttle solenoid . How do I check that ?
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
The control board needs to sense a voltage coming of stator windings to complete the run circuit or else it will shut down. Check the stator and rotor windings for resistance and shorts
Posted on Nov 17, 2013
3 Suggested Answers
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
HOW DO YOU REMOVE FULE FLOT BOWL KOHLER CONFIDANT 5 5CKM21
It is not a float issue because the motor cannot consume the entire contents of the gas chamber in one instance of a surge. This is a throttle issue.
Oct 05, 2015 | Kohler Electrical Supplies
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Need wiring sch for7CCKMR61 spec 140291 serial 326977
I can maybe help with that, as this is an old post, if you still need it let me know
Aug 31, 2012 | Kohler Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
What engine is in my rockworth generator?
i need a manual for a ( kohler RV Generator 4.50km21-RV Spec # 10111A plus need to know Motor Size Can any one help me out
Apr 14, 2012 | Electrical Supplies
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
Aug 11, 2009 | Electrical Supplies
Generator quit working
i used to work at a repair shop for kohler 98 bucks an hour to check it out. and for them to repair who knows?. i would do my best if not in a hurry to figure it out on my own. you can purchsae a service manual and stick with your basics; spark gas, and from there go deeper.
Apr 26, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
233 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
