Question about Lavazza Espresso Point Matinee Water Tank Float Cap
Lavazza Espresso Point Matinee in lamp
3 Suggested Answers
  • 19 Answers
SOURCE: Lavazza Espresso Point Matinee
Take the wand off and run a small thin paper clip thru the hole in the tip contact me at www.lavazzarepair.com
Posted on Oct 13, 2009
  • 92 Answers
SOURCE: i paid 899.00 dollares lavazza point matinee only
What is the problem?
I'm Fixing one of this right now.
Posted on Jan 12, 2011
Lavazza Espresso Point Matinee will not turn on after it has been on and then turned off without unplugging for a few minutes then plugging back in. It will work fine until I turn it off and then try to...
That would be in the temp switch and the logic chip. When it cools the temp censer is suppose to reset. Just change it, should be located in the hot plate part of the unit.
Mar 04, 2014 | Coffee Makers & Espresso Machines
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso point not heating up
The electronic control board is defective, it must be repaired or replaced.
To get a dealer address send an email to: f.vitare@lavazza.it. I could help you, but, I live in Canada. Guru
Nov 15, 2011 | Lavazza Espresso Point Capsule Machine
The water reserve light is flashing and the float is broken off. Will this cause the machine to not work and can it be repaired
This will cause the machine not to function because the magnetic sensor is not detecting contact from the float. All you need to do is simply attach the FLOAT ROCKER to the FLOAT RETAINER. The Float Retainer resembles a small thimble with two skinny pieces of plastic sticking out from the side. This allows the Float Rocker to slide onto it through the hole provided on the Float Rocker. This assembly will only work correctly one way so there may be some trial and error. To correctly install the Float Rocker and Float Retainer, have the assembly face the front of the machine. Now, if the Float Retainer (which looks like a thimble) appears to be broken a replacement will be needed. Don't worry, these are inexpensive. Locate a business that sells Espresso Point Matinee's and hopefully they will have parts.
Sep 14, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Matinee No steam out of spraut
Try unfolding a small paper clip until it is straight, stick it up the steam pipe and move it around, if this does not work, then it is most likely that your two-way valve is in need of cleaning. Should you need service you can contact 781-393-2929. We are an authorized Lavazza distributor and repair center.
Aug 10, 2009 | Lavazza Espresso Point Capsule Machine
Replacing the float on Lavazza ESPRESSO POINT
You will most likely need to order lavazza part# 87068 (retainer) and Part# 79257 (float)
Jun 26, 2009 | Lavazza Espresso Point Capsule Machine
Cold espresso
it may be the the back fuses not working or the two thermostat are not working good, or the worst possibility can be the electronic card.
Mar 19, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza point espresso machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Jul 23, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Matinee Water Tank Float Cap Logo
35 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
