Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
How to take gas tank off a poulan pro backpack blower
How to remove the fan on paulan 30cc back pack leaf blower
Go to manualslib.com and it will show a diagram of the unit. Most have keyways in the shaft and you may need a puller to take it loose be most times you can just gently place a large screwdriver or bar under them and pry up. Careful not to break the fins. Hope this helps.
Sep 27, 2016 | Poulan Pro PPBP30 30 cc Gas Powered...
I need a repair manual for Poulan Pro PPBP30 leaf blower
The best you will get is a User Manual as repairs are usually left to the manufacturer or a dealer. The head office is 5 minutes from where I live!
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/ppbp30.html
Oct 29, 2015 | Poulan Pro PPBP30 30cc Gas Variable Speed...
How do I replace the fuel line for a Poulan ppbp30?
Open the top of the machine to access the carb, Normally it is easily done with needle nose pliers.
Aug 10, 2014 | Poulan Pro PPBP30 30 cc Gas Powered...
Why does my Poulan Pro PPBP30/30cc backpack blower have no power?
It may be fuel starved from either blockage in the carb or a broken intake fuel line. You can dump the fuel and mix up a back of fresh fuel with some system cleaner added and run it through and see if the unit picks up a bit. If a system cleaning doesnt improve performance with the gas tank empty look inside the tank and see if the fuel line is broken off or split. Many times fuel lines just get broken from alcohol fuels and age.
Jun 24, 2014 | Homelite Consumer Products Backpack...
Starts right up, runs for about 30 seconds and shuts down. Any thoughts on the problem.
loosen gas cap and see if that helps. sounds like the gas tank vent is clogged
Aug 18, 2013 | Poulan Bp406 45.4cc Backpack Leaf Blower
I have a Poulan Pro leaf blower/vac. The fuel lines cracked inside the gas tank so I pulled them out & bought new ones. Now i can't get them back in to the gas tank. I understand there are
Make sure that you have the right size lines the smaller diameter line goes into the bottom hole of the tank cut a 45 angle at the end of the line as you put the line into the tank twist and push until you get enough line to pull up through the fuel filler hole then cut the line so that the 45 is no longer and slip the fuel filter on then pull back the line until the filter rests at the bottom of the tank. Do the same with the upper line except that line will only go in 3 to 4 inches. I hope this helps you.
Feb 29, 2012 | Poulan Pro Gas BlowerVacuum ()
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
16 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
