Reset eeprom toshiba regza
My tv is toshiba regza 24PB1E i would like to reset from factory
james klgr
  • 362 Answers
SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Posted on Dec 14, 2007
  • 11 Answers
SOURCE: I have a Toshiba Regza 42A3030D TV but no manual.
Paid for only:
http://www.user-manuals.com/advanced_search_result.php?keywords=42A3030D+manual&forward=plist
Or try eBay.
Posted on Sep 13, 2009
SOURCE: i wish to reset toshiba regza 37wlt68 to default
i have the same problem mate
Posted on Oct 08, 2010
bobhifi
  • 635 Answers
SOURCE: TOSHIBA REGZA 24" LCD/TV cannot
When you attach a PC to an LCD TV remember to change the screen resolution of you PC to suit the LCD TV. Right click on the desktop ( not on any icon ). Click on settings / then slide the resolution pointer to a lower resolution like 1024 x 768. Then click the apply button. Try changing to different values and press apply to make it functional. One of the setting will work for you.
Posted on Mar 10, 2011
  • 3 Answers
SOURCE: toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Posted on Mar 14, 2011
Toshiba regza no longer receives a an hdmi signal.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 02, 2016 | Toshiba Televison & Video
How to factory reset Toshiba 24pb1e
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 02, 2016 | Toshiba Computers & Internet
Toshiba regza 24pb1e
check aerial connected
Dec 23, 2013 | Televison & Video
I do not know the reset code for my Toshiba 1080P 42XV505DB tv. I am having trouble setting the Sky remote as I lost my Toshiba tv remote,
You should be able to buy a universal remote to fix this problem.
Can you get into your main menu.? If yes, try reseting to factory default. If asked a pass, try 0000.this should do the trick.
Hope this helps.
Apr 12, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
Toshiba regza 37" reset defaults
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I have a Toshiba REGZA LCD Model 42XV600A and am having problems with the picture. The picture was fine but now the colours are all out of whack. I have checked the connections and aerial reception and...
Go in ur tv menu go "Picture"go down to reset.Press it,will go back to Factory setting.The colors should be back to factory setting.Not,than ur tv Main Tuner signal board is the cause must change to fix.
Apr 04, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba Regza tv was in storage we took it out and can't find remote is there a way to tune without it? Thanks
Yes,must use the manual control on the tv itself.Very trouble some.Buy a new exact remote on website 1-800-Remotes Factory Original.
Jan 16, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
