Question about Kenmore 22313 Bagged Canister Vacuum
Kenmore powermate model 116 56512690 the sweeper will not operate when I turn it on. Everything else is functioning.
The brush on the our progressive conister stops and starts. We have replaced the belt cleaned out all areas near the belt and it still starts and stops as if it is skipping of getting stuck on somthing.
Check the brush end bearings for debris build-up and sticking bearings--remove the brush assembly, and pull off the bearing blocks. Clean the pin ends on the brush and the interiors of the bearing blocks with Q-tips, then lightly oil (3-in-one or similar) the bearing blocks and pin ends. Reassemble the brush into the sweeper head without the belt on--check for free turning of the brush. If ok, install the belt, and check for operation. Hope this helps!
Feb 20, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
My canister kenmore progressive is not sucking and is sptitting carpet powder dust all over the place. could it be it needs a new hpa filter? if so where on the vacuum would it be located?
Remove the hose from the canister, and turn on the vacuum. Does it produce good air flow into the hose port?. If ok, remove the hose from the sweeper unit and plug the end into the canister. If ok, check the bottom of the sweeper head for plugging of the air passages and inspect the sweeper bar for accumulation of thread, hair, and string. If the first test produced no air flow, then open the canister and remove the bag--turn the vacuum on and check for air flow into the motor. If still nothing, then check the hepa filter which should be near the air output from the canister. Go to: searspartsdirect.com and enter the sears model number from the information plate. The machine's part drawings will appear and select the vacuum case drawing which should display the hepa filter location and also be able to order the filter from the web site. Hope this helps!
Mar 13, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore PowerMate cannister: Reattach cannister floor piece.
You need to open the head by gently squeezing the light cover housing and lifting it off. There will be two screws underneath and once removed the lid will lift off and reveal the area where the pedal installs.
Sep 02, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore sweeper model 116-33919
Go to sears.com, click on the parts link, enter your complete model number, then you can click on the links for your vac and you can figure out what it takes, and you can order thru there also.
Jun 05, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Powermate Canister Vacuum Cleaner
Depending on which model, there is a couple of scres on the bottom, then on each side and back are release catchs that you pry up to release the top, then you can get to the belt. The other model you take off the light cover, it just snaps in place, then you can take out 2 screws from the top, on each side there is a slot, put a screwdriver up into the slot and pry out to release the tabs, then the cover comes off and you can get to the belt.
Feb 10, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore powermate front axle fell off
It will go on hard. Just angle it until you have it as far as you can go, then use maybe a hammer to knock it the rest of the way.
Jan 10, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 22313 Bagged Canister Vacuum Logo
42 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
