Question about Pantech Matrix Cell Phone
Pantech p5000 keeps restarting - Pantech Matrix Cell Phone
How do i set the time on a pantech p5000?
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauderâ„¢ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Nov 01, 2015 | Pantech Cell Phones
My pantech p2020 is not starting
perform power flee
keep holding power button for 15-20 secs ...release and turn on
Apr 21, 2014 | Pantech Ease P2020 AT&T
Pantech user manual
http://bit.ly/K74fpu
It's the third link, Change the ringtone
Dec 26, 2013 | Computers & Internet
Screen cell phone keeps blacking out
Restart iPhone
Sometimes all it takes is a restart for the iPhone to become responsive again. To restart your iPhone when it is unresponsive, press and hold the sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It is possible for an iPhone to become unresponsive if the battery drops to an extremely low level. Plug the iPhone into your computer or wall charger and allow it to charge for at least 20 minutes before using it again.
May 23, 2013 | Pantech Ease P2020 AT&T
Pantech link II unlock
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 25, 2012 | Pantech Link Ii - P5000 - Cellular Phone -...
My at&t pantech burst keeps restarting. how can i get it to turn on and not restart?
You have to reset your whole phone. Hold the power button and the volume button down at the same time until Pantech pops up on the screen and when it does let go of the power button but keep holding the down volume button down. When the triangle pops up let go of the volume button and press the menu button. Use the volume button to scroll down to wipe data. Hit the home key.. scroll down again to yes and hit the home key. Hit the home key again on reboot system. That's it ! :)
Oct 20, 2012 | Cell Phones
My Pantech c150 just keeps restarting
Try performing a hard-reset. Take the battery out of the phone for at least a minute and hold down the power button for at least ten seconds afterwards. Replace the battery and turn the phone on, and it will have hopefully cleared up the problem.
Jun 02, 2009 | Pantech Matrix Cell Phone
My sister said it happened to her crappo free phone and said that it was from having it charging while at full charge. So idk how to fix it but if you get a new phone try not to do that!
Feb 07, 2009 | Pantech Matrix Cell Phone
Pantech Matrix  Cell Phone Logo
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
