Question about Dryers
Squeaky europace stand fan - Dryers
My dyer squeaks
a squeaky dryer means the casting wheels on the dryer are broken and need of replacement their kinda like skate wheels but more durable to stand up to heat however a simple hack such as using metal skate like rollers should help in a far long run
Apr 22, 2017 | Dryers
Repair europace tower fan etf1129 can't switch on
I also have same problem can someone hwlp me please.....
Feb 25, 2014 | Dryers
How to open tower fan to clean? brand EuropAce model ETF1025
The EuroAce ETF 1025 How to Remove Cover to Clean.
This is for the EuroAce ETF 1025 specifically but may apply to other models. There are two screws on the back near the top where you carry the unit. Remove those two screws.. Next: About half way down the back cover there are two small locking tabs, one on each side. you will need a flashlight to see them. Take a knife and pop them open. its not hard. just wedge the blade in there and gently pry. Next and last: Push the back cover downward towards the base. There are two locking tabs that hook at the bottom of the cover. The cover is now removed. To assemble. Simply do the opposite. Remember ALWAYS UNPLUG before working.
Sep 04, 2012 | Dryers
The rear shock on my 2008 125 SX is very squeaky. It is the actual shock that is squeaky, not the point where it goes into the swing arm. Any suggestions??
i doubt its the shock cartridge, it may be the spring against the shock body or the upper or lower connecting joint. could also be the swingarm. remove the shock with bike on center stand and check the movement of your swingarm while checking for noise. at that time you can check the condition of the shock spring and bushings.
Oct 03, 2009 | 2008 KTM 125 SX
Squeaky noise from the motorafter running for
I would unplug the fan and clean off the motor shaft behind the fan and vaccum the motor housing and around the motor ends.
Once you've got as much dust and grime as possible removed, use some 3-in-1 oil and LIGHTLY oil each end of the motor shaft (behind the fan and next to the motor housing) and if possible, at the other end of the motor housing.
Make sure the fan is UNPLUGGED when you do this!!! Give the fan a slow spin by hand and hold upright to allow the oil to seep down the shaft into the bearings.
I usually do this once or twice a year on my portable fans and unless the bearing isn't completely worn out, it usually helps the fan spin more easily and keeps it running very well.
Hope you find this very helpful and best regards!
Aug 06, 2009 | Marvin W.B. 81400 14" HIGH VELOCITY FLOOR...
Lights and fan belt squeaking
replace light switch..and tighten fan belt GL
Jun 26, 2009 | 1999 Nissan Frontier
Squeaky noise coming from engine will driving
yes, it could be the idler pulley going bad.
check it out
or the belt itself is almost done.
replace belt every 50,000 miles
Jun 24, 2009 | 1998 Ford Explorer
Yamaha PD2500 amplifier has a noisy fan
Ive worked on a PD2500 with the squeaky fan.
It needs a cleaning and the end pins lubed.
Yamaha probably has the fan in stock
Mar 30, 2009 | Yamaha HTR-6130 Receiver
Squeaky noise when turning
Check your power steering fluid level
Feb 14, 2009 | 1992 Daihatsu Charade
Dryers Logo
18 people viewed this question
Top Dryers Experts
