Question about AEG Washing Machines
Blinking or Flashing display Bosch smu50m12sk/02 and the machine wil not start
2 Suggested Answers
  • 67 Answers
SOURCE: Kenmore He4t frontloading machine flashing F 02
U have something stuck in your water pump u need a torx 20 and some hose clamps unplug the machine take the three torx screws off the toe panel put the hose clamps on the white plastic waterpumps hose that goes from the back of the pump to the bottom of the drum unscrew the pump to the left and pull out you can also use the toe panel to catch some of the water pull anthing out of it that u can and replace everything back try taht first
Posted on Mar 20, 2007
My washing machine is only beeping and all lights flashing
I don't know the make or model number of the unit, but most likely the beeping and/or lights flashing is a digital error code being displayed. I need more info to better help you with your issue. If the lights are blinking in a pattern(ex 2 blinks followed by 4 blinks) or certain functions are blinking in a pattern over and over, that is an error code display which must be interpreted. The machine is trying to tell you where the problem is.
Aug 19, 2015 | Washing Machines
Bosch Model SHX68T55UC/02: Display says "watertap" and will not continue to run. There is water standing in the bottom of the machine. What should I do?
The machine is telling you to check the water supply which fills your dishwasher. Check if the water pipe is frozen or blocked, do you need to turn on a tap to allow the water go flow to the dishwasher ? :)
May 25, 2014 | Bosch Dishwashers
Why does the engine light start flashing when i brak
stop immediately, call AAA for a tow to your mechanic.
Generally a flashing "Check Engine" light requires immediate attention to avoid possibly very expensive engine damage.
If you have a friend like me locally who has a OBD Engine analyzer, you get the error codes, translate the code for free and fix it yourself if you have the skills. I got my Innova Brand at WalMart for $120 in Hawaii. Mechanics will charge $100 to hook up the analyzer, plus $60/hr minimum service fee.
Nov 17, 2012 | Bosch Audi A4 1.8l Engine Motor Turbo 02...
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
What does F02 fault mean?
Hello elaineginolf, welcome to Fixya. Error code "02" typically indicates a lock problem. Since not all models are the same can you clarify the model of Bosch you have ? The post category says WFL2060 but that can't be since that model has no display and faults are indicated by way of led lights flashing in a set pattern. Could it be a WFR2460 with the digital LED display ? Let me know and I'll see if I can assist you from there. Macmarkus :)
Jun 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
BOSCH WAA24270GB error code 0 and 2 backwards rr
Press START button over 10 second, its working for me
Apr 09, 2010 | Bosch Washing Machines
Have bosch classixx6 1200 express which has frozen displays a flashing key and 36 will not budge, desperate Molly
Simply press and hold the Start button for 4 seconds and the childproof lock will turn off - the key symbol will disappear from the display.
If you want to activate the lock then press and hold the Start button until the key symbol appears on the display.
Oct 22, 2009 | Bosch Washing Machines
Bosch Nexxt Premium WFMC6400UC does not start with the following status: Start/Paus light blinking Display says ready Pressing start does not do anything I have done the following: Holiding the Start...
A faulty module or timer/control panel. Unless you are getting some form of error code in the way of flashing lights or otherwise. In which case refer to manual. Good luck.
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
May 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
