Question about Goodman CLJ30AR32 Air Conditioner
Heating unit heater not turning on
    Genius:
  • Goodman Master
  • 1,363 Answers
Sequencer, thermostat, heating elrment, or fusible link.
Posted on Aug 14, 2015
Heating is limited
The system has one temp but the heater temp should be turned all the way up outside on the unit as well
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Main burners in my old utility gas heater will not ignite
A common problem with these are the safety limit switch trips, either because the fan did not come on and over heated the unit, or the unit got shut off while in heat mode, causing the switch to trip. These are usually located around the top/side of the unit heater behind a small access panel. It should be resettable by pushing in the small button in between the two connections. Hope this helps!
Dec 07, 2013 | Mr. Heater MHU45NG
New replacement in-line heater (C3B54P0-3002AU0) inop.
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Dec 04, 2013 | Maax Calla 6042 Bathtub - 101058-000
It heats for a minute or two and then stops heating.
The heater overload switch is sensing an over heating problem and is turning the unit OFF. It may be as simple as a clogged heating element. Over time they do become clogged with dust, lint, pet hair, etc. This is because the air intake for the heating element is a floor level. So, whatever is floating in the household air gets sucked into the heating element when the fan is ON. Using a vacuum with a hose and brush attachment works well in cleaning the heater element. Be sure the unit is OFF & unplugged, before attempting this. You may be able to access the heating element thru the lower louvered door. Or consult your Owner's Manual regarding the cleaning of the unit.
I hope this helped you and thanks for choosing FixYa.
Jul 25, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
No heat, heater core inlet is hot outlet is cold
Try replacing your thermostat..also you should have a heater lever switch that manually controls the heating unit bolted onto your firewall. Follow your heater hose that's connected from your engine to the firewall. The unit that your lever is connected to is your heater switch. Look for a cable that pulls the unit..... It may be broken..Check it out and LMK how it turns out>>Good Luck!
Feb 10, 2011 | 1998 Toyota RAV4
Central a/c and heat not blowing not working
Could be a circuit breaker tripped. Check the electrical panel for a tripped breaker. If they check out, then call a service tech to look at the outdoor unit. Good luck
Apr 08, 2009 | Honeywell Electronic Programmable...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
Oct 06, 2007 | Dimplex DS5598 Mid-Size Heater
Goodman CLJ30AR32 Air Conditioner Logo
26 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
