Question about Maytag PAV2300 Top Load Washer
Maytag centennial model #mvwc300vw1 spins won't agitate
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
wiringlunati
  • 576 Answers
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
Posted on Mar 07, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do I remove the agitator on a Maytag
Here is a nice video:
My Tip How it works: Direct drive washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 23, 2010
Daniel S
  • 4323 Answers
SOURCE: Maytag Centennial will not spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 22, 2010
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
The agitator on my maytag mvwc300vw1 barely moves. We used an agitator replacement kit but nothing changed. The spin cycle works fine. Does our washer have a repair we can handle?
there really isnt much more to look at when u have the issue ur talking about? Are u sure u placed the cam dogs in correctly? u may want to check the agitator spline which the agitator sits into at bottom if bad however that should also effect the spin?
Mar 12, 2015 | Maytag Washing Machines
Maytag Centennial Agitator wont spin
what is your model number is then we can get started then
Jan 17, 2013 | Maytag Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Centennial washer, will fill with water, wont spin or agitate, power is good
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Apr 30, 2011 | Maytag Centennial MTW5800TW Top Load...
Maytag PAV2300 Top Load Washer Logo
193 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
