Question about MTN Gearsmith New Commercial 7 Roller Hotdog Sausage Grill Machine 18-24pc Hot Dog Maker
Can you replace rollers for the MTN Gearsmith CY-007 hot dog grill?
I have a hot dog roller grill model#hdr565 the receptacle is broken.
Then you are stuck with it, either that or you search for a replacement receptacle online & then take it back
Nov 11, 2014 | Nostalgia Electrics Hot Dog Grill Roller...
HOW DO I WIRE POWER SWITCH
If it is only two wires just get a regular toggle switch.
Dec 03, 2013 | Nemco Hot Dog Roller Grill Narrow Electric...
I bought my son an old fashioned hot dog roller for Christmas. It worked great the first time and the second time he went to use it, the rollers wouldn't roll. I've read several reviews on this product...
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Jan 06, 2011 | Nostalgia Electrics Hot Dog Grill Roller...
How long do you put hot dogs on the roller grill?
Once you have the rollers hot (10 min.) it should only take about ten minutes for the dogs to heat up... they are fully cooked so you anly have to get them hot, but you can let them on for a much longer time if you want too, like if you are selling them at a stand...
heatman101
Apr 29, 2010 | Nostalgia Electrics Hot Dog Grill Roller...
MTN Gearsmith New Commercial 7 Roller Hotdog Sausage Grill Machine 18-24pc Hot Dog Maker Logo
268 people viewed this question
Top MTN Gearsmith Cooking Experts
Tom Chichester
ray gallant
Are you a MTN Gearsmith Cooking Expert? Answer questions, earn points and help others
