Question about Frigidaire Affinity ATF7000ES Front Load Washer
My frigidaire Affinity top loaders lid will not stay up, it slams down hard on you if you dont hold onto it while adding the clothes and detergent very dangerous can anyone help with a solution?
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
SOURCE: My Frigidaire Affinity front loader smells like mold
Ours gets a musty smell because water gets trapped in the air-tight drum. I leave the door open in order to let the water evaporate. Also, the owners manual tells you to remove and clean out the soap dispenser drawer and the area that the drawer fits into. We have to do this monthly, as both get coated with black mold.
Posted on Jul 08, 2009
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Posted on Sep 26, 2009
Do you put detergent in the frigidaire affinity front loader clean washer cycle?
Good Afternoon Jodi,
I understand that you are wondering if you put detergent in your Frigidaire Affinity washer for the clean cycle. You do not put detergent in. You will want to take the detergent cup out and put a cup of bleach in there when you run the clean cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Washing Machines
My Affinity front loader works fine but shuts down early at last 6 min no spin soaking wet cloths
Hello James Banks - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit. Thanks for allowing me to help you.
Apr 10, 2013 | Frigidaire Affinity ATF7000E Front Load...
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Smell still in clothes
Try adding baking soda to the wash. We have the same issues (son works on a dairy farm) and will on clothing resort to chlorine bleach even on colors in small amounts. Eric
Jun 17, 2009 | Frigidaire Affinity ATF7000E Front Load...
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Detergent
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Jul 26, 2008 | Frigidaire ATF6000ES Front Load Washer
My affinity washer (front load ATF6000ES) is leaking detergent
are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
83 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
