Question about LG WM-2277HW Front Load Washer
LG inverter 12 kg has childlock on and I cant use my washing machine
SOURCE: 1E displayed in the Display panel of the LG front
IE...Is a water inlet problem... clean the screens at the inlet hoses...
your fill vlave is not working,,, turn off the water supply and remove the clamps and undo the wires, could be just a plug in, may have to cut the wires get you a new one reinstall it with the flow going in the right direction and you will have water!!!!
Posted on Aug 30, 2009
techbuster
  • 5081 Answers
SOURCE: lg inverter frontloader washing machine wont turn
CL is about the Child Lock which is done by pressing both the buttons together. To release the same do press both the buttons under the display simultaniously
Posted on Sep 06, 2009
  • 155 Answers
SOURCE: LG washing machine fuzzy logic 8.5 kg not agitating
The reason to this problem can be due to any one
of these reasons.
Lid Switch
Motor Coupler
Belts
Clutch
Drive Motor
Drive Pulleys
Transmission
Agitator
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
  • 343 Answers
SOURCE: my lg washing machine is a semi automatic model
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Posted on Apr 18, 2010
LG true steam inverter direct drive 9 kg f1479fds5 on a screen AE error what s happend
The AE error is indicative that there is a leak somewhere in the washer and it has triggered the flood protection device found at the bottom of the machine. What you should do is find out if there is indeed a leak. Try tilting it forward and find out if water will run out. If you can see water leaking from the water, call a repairman!
Jan 31, 2017 | LG Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
Fuzzy logic 12 kg model T9507TEFT0 overfills water
your water level switch is most likely bad or there is trash in the line feeding it.
Mar 17, 2014 | LG Washing Machines
Lg Washing Machine Manualmy washing machines just started coming up with 1E in the display part what does that mean.. i have a lg direct drive 7.5 kg front loader, WD12020D
there is a problem in water inlet valve.....first turn off the water tap.then remove water inlet hose from washer end.after that see the inside of the valve.there is a small water filter in the valve.....take it out it using plier ...then clean it wel....now replace it correctly....now your problem will ok
Jun 02, 2013 | LG Washing Machines
I cant start that machine and how to use
Check to see how the machine works: Click on Washing machine
Feb 01, 2013 | LG Washing Machines
My lg washer on the display is saying CL what does this mean ? thanks
Hi it means the childlock is on, on mine i have to press the wash and rinse buttons together and hold it till it beeps.
sharon
Jan 05, 2011 | LG WM-1480FHD Front Load Washer
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Top hoses leaking just a drip but annoying from top loading lg fuzzy lodgic 8 kg washing machine
Hiya .. look for a break in the place they are fastened.. may have become warped and brittle. If you cant find any suspected break .. just Tighten a touch.. should sort the prob ..
Regards Faggly
Mar 27, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
