Question about Taylor Electrical Supplies
Peugeot 206 2l hdi, for trailer wiring what are the road light wire colours please
4 Suggested Answers
pops296
  • 174 Answers
SOURCE: trailer wiring colour codes
try http://www.etrailer.com/faq-wiring.aspx. They may have that info.
Posted on Jan 29, 2010
  • 8 Answers
SOURCE: wiring colour for connecting trailer lights
Your best bet is to go to an auto parts store or dealer and see if they have an adapter for trailer lights. Most of the newer vehicles have adapters the just plug into the existing wiring harness and you don't need to worry about splicing things. Also on some vehicles hooking up directly to the wiring harness doesn't work too well because of the circuit not being able to support the extra voltage drop. The adapter usually have that taken care of.
Posted on Jul 14, 2010
  • 280 Answers
SOURCE: Fitting trailer wiring to peugeot partner van.
Hello, if you have a test light handy with a sharp tip on one side than, start with your parking lights on and check to see which wire it is, if you have a heavy bag of potatoes or similar, you can use this when it comes to the brake lights :)
Posted on Feb 18, 2011
Ca't get the mine beam headlights to work on my Peugeot 307 hdi. have changed bulb and checked fuse. Canyou advise
Is the wire hot or not? You might have a short and if good that check your light switch
Feb 27, 2013 | Cars & Trucks
Please help western australia.britax trailer lights not connected properly.this is how currently connected.left hand trailer light top pin yellow,side pin green,bottom left pin brown,bottom right pin...
plug wiring is in
the following web site
ww.narva.com.au
the site is very specific for 7 pin , 6 pin and rectangular to round 7 pin
the small tag that you have to use to put the plugs together is identified at the top oh the round plugs
you can get the site by googling and typing in ---trailer plug wiring australia
Apr 02, 2017 | GPS
Fitting trailer wiring to peugeot partner van. need to know van wiring colours, dont match trailers wiring colours
Feb 18, 2011 | 2006 Peugeot 604
I am in the process of wiring a round five-pin female harness plug on my Road Dog trailer to my 2005 Harley Davidson Road King Classic. I will need a five pin male receptacle and some type of wiring...
Firstly I would not be useing round plugs secondly I would not be wanting to use an adaptor or converter as you call it I would be going with a male & female flat plug. why you ask simply because they are much easier to mount on both your trailer & your cycle eleactricaly one join is safer & far less likely to come apart in service than something with an adaptor in the middle of it as most of the flat variety of plugs are mostly seven pin you wil be left with two unused pins which you can utilise for clearance lights or any other accessory you might care to use later .You will need one pin for common earth one for tail light one for brake light & one for each indicator the easiest way to wire these is to locate the main wireing loom running to the tail light & indicator assemblies determine which wire operates whiich light as you are unlikely to have wire that accurately matches the original I find it use full to draw a diagram indicating the colours onth original loom& their function thenthe colours you have used to run from the loom to the female plug always mount the female plug on the towing vehicle as it is the more weather proof of the two once you have determined your wireing colour code wire the male plug to the trailer makeing sure that th apprpriate wires are conected test as you go is the surest way of getting it right the first time with the satisfaction of a job well done BY YOU qall the best
Mar 08, 2010 | 2005 Harley Davidson FLHRS - FLHRSI Road...
PEUGEOT 206 HDI STARTING PROBLEM
your ecu monitor.. emissions control unit mod is done! i dont think this is a cheap fix. either wait for warmer weather,, sell the car or find a dealer to fix this diesel puppy...word of advice .. dont buy peugeot in this country .. or any country...joke.!!
Feb 26, 2010 | 1989 Peugeot 405
2005 peugeot expert 2.0 hdi turns off?
Sounds like a flakey connector - try hunting down all the connectors you can find under the bonnet. Separate them, spray with WD40 and reconnect. Start at the engine management computer (silver block with fins on and lots of wires coming out). Take great care not to bend pins.
Jun 08, 2009 | 2006 Peugeot 505
Peugeot 406 hdi 2000 [Wreg] front @rear fog
Send me your car chaisses number to get the wiring diagrem for helping
Mar 02, 2009 | 1991 Peugeot 405
ESP and warning lights on Peugeot 407
abs esp warning light coming on peugeot 407
Feb 15, 2009 | Peugeot 407 Cars & Trucks
Reversing light
its easy, on top of box you can see the plug, normally a two pin i think your switch or plug is white, you can unplug and stick a piece of wire across terminals, then check if lights are on, if not its not the switch, do this and tell me how u got on
Jul 24, 2008 | 2005 Peugeot 405
Electrical Supplies Logo
61 people viewed this question
Top Taylor Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Taylor Electrical Supply Expert? Answer questions, earn points and help others
