Question about HP Photosmart 3210 Printer
Ink system failure
Help this is the warning i'am getting
  • Anonymous Jun 11, 2008
    ink system failure, unable to copy,fax or print.Refer to printer documentation.
  • Anonymous Aug 12, 2008
    ink failure system
    error 0xc18a0001
Turning the printer on and off will not solve your problem. If you get ink system failure you most likely have air in your ink system. This will happen after months of use -every ink cartridge you reload and purge will have a little bit of air trapped in it and over time it must add up. You have to do a system reset which causes your printer to start over and do a full purge of ink through your system. This is what happens when you do your first ink system set up when you open install new ink cartridges. To do a ink system reset you must first:
1. After your printer gives you a ink system failure you will need to press and hold down ok and cancel at the same time and then press the start button once. (make sure you hold the cancel and ok down until the system shuts down and then release).
2.Now (Again) hold the cancel and ok Button down and and press the on button again -making sure to keep holding down the cancel and ok until it shuts itself down again. It will seem like it is starting up again up will then just shut off. Now once it has shut off for the second time (It is VERY important that you have a new set of ink cartridges installed before turning on the system for the second time) This is because it will do a full ink purge and rid the trapped air in the system. If you have old ink in it or almost empty it will most likely not purge enough. A new set of ink works best- You can go back to your old ink after if you like and keep the "new" set for back up when the system fails again down the road (it will fail again -this is poor designing by HP).
3.Now once you have shut down the system and loaded a fresh set of ink (all 6 of the ink cartriges) you can now press the on button (at this time you should get a reset code the come on first and the printer will run its purging of the air and new ink.
4. You might have to do this more then once to rid all the air out of the system-keep trying and after 2 -3 times it will stop giving you the ink failure. I have fixed my printer many times by this fix for many years.
Good Luck!
Posted on Jan 26, 2008
Good advice but after repeaded tries none of the above works. I may trashed the printer. The ink costs is to much for to keep trying the solutions.
Posted on Apr 18, 2008
Ink waste tank filters need replacing
Posted on Nov 05, 2007
I have a 3210 that was fixed first try thanks to nik.
1. Unplug the power cable from printer while the printer is on.
2, Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
3. Just turn on the printer and configure your printer new.
I hope the LORD makes Nik a wealthy man for this solution.
kat
Posted on Feb 15, 2010
    Problem Solver:
  • 14 Answers
An ink system failure code is displayed on the product's Control Panel . Solution Step one: Identify the error code All error codes starting c18axxxx (where xxxx is some combination of numbers) and the specific error code c05d0082, service the product. For any other error code, continue to the next step. Step two: Reset the product
  1. Turn off the product by pressing the On button.
  2. Unplug the power cord from the back of the product.
  3. Plug the power cord back into the product.
  4. Turn on the product by pressing the On button.
    NOTE: Sometimes Ink System Failures cause a carriage stall when the power to the printer is cycled. If the Ink System Failure requires the product to be returned, there is no need to resolve carriage stall issues with the product.
Step three: Service the product If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Posted on Nov 15, 2007
Error code OXC4B827F
This is an Ink System Failure message. I would try this guide. 'Ink System Failure' or a '0x...' or a 'C2...' Error Message Displays on the Front Panel. To help resolve the issue.
If that doesn't work, please call our technical support at 800-474-6836. If you live outside the US/Canada Region, please click the link below to get the support number for your region. http://www.hp.com/cgi-bin/hpsupport/index.pl.
Oct 12, 2015 | HP Officejet 4630 Inkjet Multifunction...
Ink system failure
Plz provide the exact error message
Mar 22, 2014 | HP Photosmart C6180 All-In-One InkJet...
Ink failure ink system failure error oxc 18a0001
The "ink system failure" error is caused by air in the ink feed tubes. We have 2 articles posted on our web site giving step by step guides to purging the air from the tubes and clearing the error. You can find the articles at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C8180 InkJet Printer
HP Photosmart C6380 - 0xc19a0023
This problem is impossible to troubleshoot by just typing in this little box. HP support has documentation on this problem for your model:
HP C6380 Ink System Failure
I hope this helps!
Dec 27, 2009 | HP Photosmart C6380 All-In-One InkJet...
Printer says ink system failure after refplacing
We have a step by step repair for this printer on our web site at: www.ccl-la.com/HP.htm
This should get you back printing.
Buddy
Corporate Computer
www.ccl-la.com
Jul 28, 2009 | HP Photosmart C7280 Printer
Error message: ink device failure oxc18a0506
Perform the following on your printer http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jun 18, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
Nov 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart 3210 Printer Logo
1,558 people viewed this question
Clive
Clive
