How do you manual open door on model 970-c-44052-00 kenmore
Kenmore instruction manuals
The Sears site has many of the manuals in PDF. Know your model number (open the door, look upper left corner on machine) and it will go quicker.
Jul 21, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore H2 Plus door won't open.
see the causes and fix it: God bless you
irst to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab.
Door Switch
You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Jul 18, 2012 | Kenmore Washing Machines
Dryer will not come on after setting timer and pushing start. No light when door is open.
Most likely the door switch is bad. Listen for a click when the door is just opened or closed. Noclick = bad door switch. The number you passed is NOT the model number. The model number will have 3 digits followed by a period and up to 8 more digiits after the period. i.e 110.xxxxyyyy or 110.Cxxx.yyy (examples only as it can be other numbers depending on the manufacturer.) There are other numbers starting with 417 and 665 also.
This is what I think your model number is: 11064672400
The door switch is item 41 below link: PN 3406107
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11064672400/0582/0151200/K0404036/00002?blt=06&prst=&shdMod=
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3406107/0026/110/Model-11064672400/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11064672400&subCompDesc=Cabinet%20parts&brandDesc=KENMORE&modelDesc=RESIDENTIAL-DRYER&blt=11
This manual will help you:
http://applianceassistant.com/pdf/27gasElectricDryers.pdf
The top has to be opened and the front panel taken lose and tipped out to change the door switch.
The manual is not straight forward as to the sequence of remofing things but you remove the top... open the toe panel loosen the lower front panel screws and then take out the 2 upper mounting screws for the front panel to gain acccess to the door switch. POWER OFF at the CB or dryer unplugged of course!
Thanks for choosing FixYa,
Kelly
Jun 25, 2011 | Kenmore 64672 Electric Dryer
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
My kenmore 46745 or 46749 (both models listed on the manual) door is jammed. I accidentally opened the oven door, stopping a cleaning cycle after only 15 seconds, and now the door will not close...the lock...
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Nov 26, 2010 | Kenmore 45781 / 45782 / 45784 / 45789...
How do I opening a lock door on my Kenmore Oven? Model #790.95599102
we lost our owners manual for our kenmore elit smooth top range and forgot how to use the self clean oven.
May 10, 2010 | Kenmore Microwave Ovens
Door pops open during wash cycle
this is joyce
What I would do in this situation is fix the door lock first before I would do another load of clothes. you can go to Kenmore.com put in your model # and download your manual to your machine if you want to fix yourself
or you can call service tech out. I will help you find one in your area if you need.
thanks,
joyce
Feb 04, 2009 | Kenmore 44072 Front Load Washer
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
