Ppendo pad model pndpp41dg7bl won't boot up - Computers & Internet
    Scholar:
  • 79 Answers
We need more info about what happened that could have caused it, ok? Til then, here's a lil thing I just answered with someone else.
"ALWAYS try all the easy simple solutions 1st before you get into any complex ones! Then if simple solutions don't work, try others, but I'd sure avoid opening my laptop and monkeying around with stuff inside!
Usually the reset routine by unplugging the power cord and take out battery for a minute works,or try unplug/battery out/ hold power button down for 2 minutes, hook all back up again, BUT there are so many problems that can cause this same issue. It can be caused by a dead battery, bad power cord or connection, or liquid getting into the pc, or a new ap that is causing it. Mine even once had a problem that somehow "pages" in my system folder were locked, though I didn't lock them, but it kept my pc off til Windows found it's own solution online somehow. Just recently I installed a new ap that made my startup ap keep trying to keep it from running, and it kept insisting, so it took about 4 minutes before pc came on finally, and I then uninstalled that ap fast. As you can see, so many things can make it happen. Be careful what you do to attempt to fix it! If possible, always tell us exactly what you did before that happened. One thing you can try if it happens to you is- do the unplug/remove battery a minute, put both back in/on, and then when you start it up, before it starts loading Windows press F8 over and over til SAFE mode option comes on, pick safe mode, and go find in your system the Control Panel, then "Recovery", then "System Restore". That can take your PC back in time to a day or 3 before present and you lose no data. Pick a time very close to the last time you used the pc, and run that. Often that fixes any problem within the pc itself. Try again with a different time before giving that up. I'd never try other things 1st, til I tried these simple things.
Ask your question as a new question if that doesn't work for you, and give us details about what happened,please.
If you got liquid in it, DO NOT run pc for a couple weeks, and let it dry completely before you try to run it again. If it could be the battery, DO NOT go buy another one without being sure that's really the problem. Take your pc and old battery to a place that can check it for you, like a battery store. Don't just follow advice to open the pc and work on it!! If you're not an expert, you can ruin your pc.AND for your sanity's sake, always keep a recent backup! Paragon makes the best free backup aps. It's even possible to make a flash drive with your system only on it!
Posted on Oct 21, 2013
My Lenovo mouse won't work. It connects and registers but won't move? Is there any help?
Try booting to safe mode and check if your mouse works inside safe mode.
Restart the computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight either safe mode or safe mode with networking. Hit enter.
Once you are inside safe mode, check if your mouse works. If it works, then you just need to update the mouse driver. You can use RadarSync to search and install the update into your computer. You better use Safe Mode with Networking because RadarSync needs the internet or even the manual updating process needs an internet connection.
I hope this helps!
David
Apr 12, 2013 | Lenovo Computers & Internet
Acer notebook s3 series model no. MS2346 - won't boot up.
dear helpers my Acer notebook s3 series model no. MS2346 - won't boot up after i re-enstoled windows 7 and it dont have a CD-ROM.
Dec 06, 2012 | Acer Computers & Internet
TOUCH PAD ON MODEL WFW8300SW01 WON'T START WASHER
You will need to replace the interface board on the unit. Here is the board to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 23, 2012 | Kenmore Dryers
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Brakes squeal and won't release
Causes: Broken spring in the master cylinder.
Dirt and grime in the caliper needs to be cleaned out.
Dust seal in the caliper full of grime, torn or not there.
Caliper not lubed.
Unbolt the caliper and remove it. Don't remove the hydraulic line yet. Check your pads for dust and grime clean them as much as possible. A good product is brake cleaner in the spray tin. Don't get it on your paint or tyres. Make sure everything is clean again, you might have slider pins check them and the rubber boot. Just prise the boot up and take a look. If it looks dry under there add a bit of silicone lube. Don't let the lube get on the pads
Oct 03, 2011 | 2002 Honda XR 200
When my wow pad boots up it goes thru the infotec screen to a lite blue screen it cannot find E:/ to restore or anything it just stays on the blue screen.
Hi, maybe you can take a try of this rescue program called BootSuite. I came across similar blue screen situaiton on my HP laptop (win 7) and it helped me get rid of it and rescued my data back. It is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all. Good luck.
May 20, 2011 | Computers & Internet
Changing front brake pads. Front brake caliper won't move with C-clamp. Why?
what year its the car or truck? try turning them around clock wise some calioper work like that in some cars like onda cars you migth need the tool that come to do this kind of caliper work .you can tell by looking at the serface of the caliper cilinder.
May 19, 2011 | Ford LTD Cars & Trucks
Acer aspire 1 netbook won,t boot up.
Hi
When you first turn the machine on hit F2, that will take you into the bios menu, i don't know what version your machine is using, but the information is usually on the first page, you should find it easy enough because it will be next to the CD/DVD drive.
Feb 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
