Question about ASUS Computers & Internet
I'm having a problem with my laptop AsusPro555. the problems is with the when i turn on the laptop it starts up and then turns off again... green light turns on but suddenly cuts off again.. i Don't know something must have wrong from the operating system inside .. please help me.. Daniel
    Sergeant:
  • 401 Answers
Let's start with the basics:
A. Is your battery charged?
B. Is it holding a charge?
C. Your laptop could be getting too much or not enough juice (power)
Posted on Oct 21, 2013
Futjitsu Lifebook A6030 cannot turn on, green light keep flashing, laptopn procdessing sound . First night was three light turn on , laptop cannot turn on. following night was green light on with laptop...
sounds some problem with RAM check if you can open it from back panel and remove case fromRAM and remove RAM and reinsert if it helps then good otherwise let me know again
Aug 20, 2011 | Computers & Internet
Hello! My HP nc6220 notebook will not turn on-if you press the on button an orange lightening bolt flashes. I have it on the charger-
pull the battery out and try again. If it works the battery needs replacing.
just an fyi those are good laptops
Mar 30, 2010 | HP Compaq nc6220 Notebook
Fujitsu Lifebook laptop will not turn on
It is one of two things and that is hard drive or motherboard. To see which it is, take the hard drive out and start the computer. When it starts, tap the F2 key, if the computer gets into the BIOS and you can make changes, then I would venture to guess the problem lies with your hard drive.
Oct 02, 2009 | Computers & Internet
Acer Aspire 5520 does not start up, power light blinking green
I think it might be the motherboard, if its not regulating the voltage properly then to much will go thru the motherboard and the fan won't be able to cool things down properly. Eventually then the motherboard will fail and then no video like your having now.
Try these steps anyway just to be sure:
only hook up the AC Adapter keep the battery disconnected. See if it turns on, if you still get a blinking green light then go ahead and turn the laptop off.
At this point, unseat and reseat the memory one stick at a time in each slot one at a time. Try turning on the laptop after each stick reinsertion.
If that doesn't do it then disconnect the hard drive and the dvd drive from the laptop.
Then try turning on the laptop, if you still can't get video then the motherboard is bad and would need to be replaced.
At this point at least you would know for sure.
Aug 19, 2009 | Computers & Internet
Laptop (sony) will not turn on when button is pressed.
Just remove the battery from laptop and again fix it carefully.
Mar 12, 2009 | Sony Computers & Internet
Canon Pixma Printer trouble
hi dear
try with this metode
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
oke try to print
thanks
cropp
Mar 17, 2008 | Canon PIXMA iP1600 Printer
Won't turn on
Try removing the battery and then plug it in. If it starts up put the battery back in it and try again.
Jan 29, 2008 | HP Compaq nx9030 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Computers & Internet Logo
42 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
