Question about Acer Aspire One PC Notebook
Acer Aspire One notebook.when turn on,starts to boot goes windows did not start screen,can choose option and windows starts to load then just shuts off.if you do not choose option shuts off after about 20 -30 seconds.will not stay on for more than 30 seconds or so no matter you push buttons or just turn on and watch.was working fine 20 mins prior.turned back on and this.
    Problem Solver:
  • 13 Answers
This is generally a hardware issue - if the computer is under warranty get it fixed through Acer. If not you may need professional help. You don't mention how old the laptop is but if it is older than a year or two and you live in a dusty environment it could be overheating. If the fan is not running or always running on super-high then it is probably overheating.
Another thing to try is using a boot CD (any boot CD will work) and see if the computer still shuts down after that 30 seconds. If yes, definitely hardware. If not, possible that it's a windows issue.
Hope that helps!
Dave
Posted on Oct 21, 2013
3 Suggested Answers
sacraty
  • 64 Answers
SOURCE: Acer aspire one not booting
your laptop has been turned off without shutting down. all your laptops registries are probably messed up. the easiest way to do is to reformat your computer or restore it to factory settings. unless you have some important files that you cant afford to lose.
Posted on Feb 07, 2009
  • 942 Answers
SOURCE: when trying to boot up
Hello
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
Regards
PCmania
Posted on Sep 25, 2009
Acer aspire will boot up then i shut it down if i try to switch this back on straight away the acer screen appears but then goes blank and does not load
I am quite sure the operating system is corrupted. Just install fresh operating system.
But still you mention, that it is booting up but it is just blank screen or shut down.
Try to press F8 key once when start up boot to go to ADVANCE BOOTING OPTION. If you are lucky, it will load this option and choose LAST KNOW GOOD CONFIGURATION. or if you have the Operatins system installer CD, put inside the CDROM and repair the operating system.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 12, 2011 | Acer Aspire 5920 AS5920 Notebook
My Laptop will not start up goes to a blank screen.
Try running Last Known Good Configuration which should fix your problem.
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows. I
Jan 16, 2011 | Acer Aspire 3680 Notebook
Hello i went to restore my acer and now it's stuck when i turn it on first you see acer screen then it goes to starting acer recovery management then windows xp screen and then it says please wait then it...
Follow the steps below,
Dec 20, 2010 | Acer Aspire One AOA150-1635 Notebook
Acer 5536 boots up goes to screen to select safe mode, tried both modes but after the selection screen goes blank with a little loading circle but goe sno further, no log in screen or anything, please help
Nov 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
After installing an automatic update, upon re-starting, my computer will load the windows xp welcome screen, the blue bar, under the windows xp icon, scrolls as if the computer is booting up. The screen...
Sounds like the HAL.DLL problem that I have with my Aspire One.
Try booting off a genuine Windows XP disc and choosing the 'recovery console' option. At the command line, type 'CHKDSK C:' and press Enter. If you're lucky, that will do the trick.
Feb 07, 2010 | Acer Aspire 5050-3242 Notebook
Acer Aspire One loops on start up screen. All it does is show the acer logo, then shows the ''windows was shut down improperly'' screen with all those options and then goes to the windows xp start up...
Try tapping F8 when the acer window shows, when it shows the muliboot option, scroll down to "Last Known Good Configuration" and hit enter. If it does not boot normally, you will have to get an external dvd drive and boot off the drive with a windows installation disc to perform a repair.
Jan 07, 2010 | Acer Aspire One PC Notebook
When trying to boot up
Hello
Regards
PCmania
Sep 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire shuts down before it loads the windows OS... pls help
Try rebooting, press F8 key repetedly until the boot menu is shown. Try booting into safe mode.
If you can get into safe mode, hit start -> run and type "msconfig"
Choose the option to NOT load the startup items upon boot and restart. This will let you boot if there was a program that was starting automatically and intefering with boot.
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire One  PC Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
