Question about Garden
250 sthil weed trimmer flywheel magnets .how many magnets on it
  • 7,482 Answers
Hi diana
You have just one magnet...it is the one that activates the electronics to give fire to the spark plug
Bud
Posted on Oct 22, 2013
5 Suggested Answers
  • 376 Answers
SOURCE: what should gap be between ignition module and
Pull the module back, tighten it up and align magnets on flywheel with module. Put a business car between them and loosen the module. It will move against card. Tighten the screws there. It's set.
Posted on Jun 27, 2009
moretons
  • 155 Answers
SOURCE: Lack of power
Hi usually about 10 thou for most units.
Posted on Sep 10, 2009
Testimonial: "Thanks for your input. I have not checked this yet but I will within the next week. I know someone had this unit apart so I will let you know. Thanks"
wilsodfarm
  • 986 Answers
SOURCE: no spark
The easy way is just use a buisnes card it work great,I hope this helps you And thanks
Posted on Sep 11, 2009
rycgl
  • 1545 Answers
SOURCE: what is the air gap between the coil and flywheel
Set it at about .010"-.012". That is about the thickness of a standard business card (which many use to do just this same repair).
Posted on Sep 11, 2011
Testimonial: "Thank you very much! I've been punishing the internet looking for an answer. You have made my day! Thanks!"
Why does my sthil fs66 weed trimmer run when choke but dies when off
Fuel issue, adjust carb, fuel lines, and or rebuild carb.
Aug 31, 2014 | Garden
Sthil fs 85 trimmer runs only on starting fluid
check for breaks in fuel line, check fuel filter.
May 04, 2014 | Stihl FS 85 Weed Eater
250 sthil weed trimmer burning spark plug with oil
Diana reduce the oil mix slightly in the fuel mix and then give it a few goes to reduce the oiling.
Oct 21, 2013 | Garden
My sthil fs 80 has new carb and new rings. has spark but wont start
Is fuel getting into the cylinder.? Is the spark continuous, check gap between flywheel and ignition module. 0.25 filer guage.
Mar 04, 2013 | Stihl FS 85 Weed Eater
25 cc craftsman weed trimmer.\r\nNot getting spark
If you're sure it's not getting spark, the first thing to check would be the "air-gap" setting between the magnets on the flywheel and the ignition coil module . The correct setting basically only requires the use of a regular business card and is around .010"-.014" If there is an air gap present, check it and then you can move on to diagnose the coil module ( they don't go bad very often) if necessary.
Jun 08, 2010 | Craftsman Garden
Just want the gas oil mix for a 25cc weed wacker
if using sthil oil the mix is 50:1 if not then its either 32:1 or 40:1 not to much dif
Jun 08, 2010 | Homelite Mighty Lite Lawn Trimmer
H232R weed trimer won`t start no spark new coil
make sure the shut off switc isn't shorting out and the flywheel may not have enough magnetism in it to create a charge in th coil.
Apr 30, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
How to replace coil on stihl fs85 weed trimmer
Remove the starter & cylinder cover and look for the coil mounted next to the flywheel. Remove the 2 screws holding it to the cylinder and cafefully pull the wires through the clips that hold them to the block. Install the new coil in the reverse order and set the air gap between the flywheel and the coil with a business card. Let the magnets on the flywheel pull the coil towards it with the business card in between. Tighten the screws and spin the flywheel to remove the card. Reassemble the stater and blower housing.
Sep 05, 2009 | Garden
Sthil weed eater will not run when hot?
you will need to replace you muffler so the machine can get rid of it's exhaust
Jul 23, 2009 | Garden
What should gap be between ignition module and flywheel magnets on troybilt 575ss 4 cycle weed trimmer? It is a year 2006 model.
Jun 27, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
