Question about Toshiba 42AV500U 42 in. LCD HDTV
My 42AV500U LCD TV acts like a ghost is pushing the volume-down button! When this happens, I push volume-up on the remote, and the volume bar goes up and down like it's competing, but volume go all the way down if I let go. This happens about 10% of the time I use the TV. It seems to happen more often in humid summer weather (yeah, sounds crazy), but that's the only flaky connection I can see. What's puzzling is that it usually happens after the TV has been on a while and is warm, but can happen from the start or after an hour, so it's not a temperature problem. Sometimes, the problem is infrequent and sometimes it's pretty agressive and I can't get the volume to stay above zero. There's a bit more: I use an antenna, and I can use the menu's add/delete channels feature to skip some channels when I surf channels up and down. What's goofy is that some of them will not "stay" turned off, like 5-2 and 7-2, but other subchannels will stay off. So, after I pass the channels once or twice, they reappear as being turned on. Lastly, and this happens rarely, I turn the TV on and the LED power indicator lights up and I hear TV sound, but the screen's backlights don't come on. I turn the set off and on again and all is well. I took the back off the TV and blew out everything with clean compressed air, including the control buttons on the side of the TV while bouncing them to make sure they are clean and free (they are). No improvement. Does anyone have a suggestion as to what may be the cause? I didn't find a software update for the TV.
4 Suggested Answers
  • 179 Answers
SOURCE: My TV has sound but No image!!!
a 42hp66 is a plasma set,, the y-sus or the z-sus circuit board has probably gone bad.. as these are expensive parts you might want to have a technician determine which one of the two is bad before ordering both of them
Posted on Nov 28, 2007
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
  • 668 Answers
SOURCE: The volume goes up automatically, then after a few
Most of the time it is the touch button assembly on the tv. The Volume down touch button switch is sticking.
I hope this helps,
Skyassoc
Posted on Dec 08, 2010
Television volume down button sticks.
spray windex or 409 on the button n press it as you spray it n around the button. Loosen the grime in and around the button.
Sep 24, 2012 | Magnavox 32MF369BF7 32 in. LCD TV
The volume up button on the remote and the tv are not working at all and the volume down button works but it does not turn the volume down instead it cycles through what seems to be different modes of...
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
Jul 15, 2011 | Samsung CXD1342 13 in. Combo
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
TV turns on at odd hours by itself
Hi, I had the "Ghost In The Machine". I tried out what I descibed in my original posting.
#1. I unplugged The Set.
#2. I pushed in and held in the power button in for about 5 minutes before bedtime. ( The PC trick I learned) I gave it 5 minutes because a tv set has much more power inside it.
#3. I again pushed in and held the power button in again for 3 minutes the next morning.
#4. I plugged the tv in again. The red standby light was lit. The set did not immeadiatly come on when I tried to power it up.
#5. 5 Minutes later I returned and hit the power button on the remote and it came on like nothing ever was wrong.
#6. It has been fine now for 3 days!!! Powers up when commanded and shuts down like normal. It has yet to come back on or act up as it was doing.
I will keep a watch on it and if it starts up acting again I will repost. I hope this information will be of use to anyone who experienced the same problem. It didn't cost a dime, just some patience. Thanks for a forum that people can exchange information and save trouble and money unless all options are exhausted. Bill
Mar 09, 2008 | Philips Magnavox 20MS3442 20" TV
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Comcast remote
true most all the new lcd panels use a new code that no remote has.
about all you will be able to find is the on/off code if you scan for it.
Jan 06, 2008 | RCA Universal Remote Control
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Toshiba 42AV500U 42 in. LCD HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
