I have a Sony projection tv KP53v45. It is about 9 years old. It wont turn on. The stand by light just keeps flashing, no picture or sound. I took off the back but I don't know what I'm looking at. Is it worth attempting to repair?
Comments:
Sep 28, 2007
- The light just keeps flashing red continuously. No pause. Thanks for your help.
Nov 05, 2007
- I wish TECHMAN would come back and offer more advise on this issue. If not maybe someone else will see this and offer some advise. We would all very much apprietiate it.
-   i have a sony 52 inch projection. when i try to turn it on, the led flashes red 10 times. it clicks on but no picture just sound. -   THECON
Jun 27, 2008
-   I have a Sony KP-53XBR35 Rear Projection TV that continues to flash the red Timer/Standby LED about every 1 second, and I have no picture or sound. I have powered it down several times, even overnight, but when I power it back up, I have the same problem.
I do not have a remote for this TV. My Grandson simply tried to turn the TV volume down on the front of the set when this happened.
Can you tell me what this code means and what is necessary to fix it?
-   my akai pt5598hd red light blinks 10 times when I turn it on but then no picture or sound. -   Guest
Mar 13, 2008
-   sony 2005 46" projection stand by light blinks 9 times wont turn on if you try 5 to 20 times will turn on and work fine called sony and did shut down reset no help-   Guest
Jan 27, 2008
-   my tv will not turn on the green light on the front just keeps blinking even after pressing the reset button and even unpluging it to reset it-   Guest
i had same problem after house power switched off 3 times in same day disconnected power left overnight worked ok i will still take tv for a service .
red light was blinking 10 times
It may be worth repairing, depending on exactly what the problem is. The flashing light on the front is a clue to where or what circuit possibly has a problem. That is a self diagnostics in this set. How many times does the light flash, and we can give you a better idea on what or where the problem is.
Was this helpful?
Yes
No
Solution #3
posted on Jan 18, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
it's probable transistor output horizontal short-circuit and the power switching can't start because the limiter is on
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS...
(More)
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS EXCELLECNTLY NEVER HAD A PROBLEM WITH IT. NOT USED AS MUCH AS A FAMILY ROOM TV, WHICH ARE ON CONTANTLY. WE WERE TOLD THAT THESE WERE NOT OPTIMUM FOR GAMING THAT WAS FINE FOR NOW. WE ARE LOOKING TO REPLACE IT WITH A LCD. WHAT WOULD BE A GOOD SELLING PRICE FOR THIS OLD UNIT.
switched on my flat screen tv model no 40wlu530hid i could smell burning then the screen went blank....
(More)
switched on my flat screen tv model no 40wlu530hid i could smell burning then the screen went blank. now the screen flickers so you cant see anything and and i only have sound. i have tried to get it replaced at the store where i bought it from but because it is a month out of its guarentee the wont replace it and i have only had it 13 months.will it be easy enough to repair myself or will i need to get a repair man to look at it?
turn on the tv,green light comes on and instantly goes off - this happened after i lost my...
(More)
turn on the tv,green light comes on and instantly goes off - this happened after i lost my electric,and had it pluged in to a surge bar
I am having the same problem that is describe here.. I have a Sony KP-61XBR48 rear projection TV.. The stand by light keeps flashing but no sound or picture.
Comment by Guest, posted on Nov 11, 2007
I too have aproblem with the stand by light flashing and the tv not turning on what did you do to fix yours?
techman can I get your e-mail address. I have a sony KP53V45. The tech said that I need an "A" board but I don't know what the part number is? Can you help me?
Comment by Guest, posted on Nov 02, 2007
When I try to turn on the tv the green light flashes briefly then the red standby light starts flashing and doesn't stop. I can't get a picture or sound to come up.
