Question about Panasonic SC-HC271 iPod Dock/CD Player Micro System
Is there an adapter for iphone 5 - Panasonic SC-HC271 iPod Dock/CD Player Micro System
I have a Hype power stick 2200Mph and the cord won't fit in my iPhone 5c do I have to use another cord I thought it worked with my iPhone because that's the cord that came with stick
Remember that Apple changed the cable that them devices uses. Since iPhone 5, the apple devices uses the lightning cord. As you say, the hype power stick 2200Mph cord is the old cable of 30-pin. You'll need an adapter or maybe another cord.
Here you have an adapter certified by apple:
Lightning to 30 pin Adapter
Here you have an lightning cable that will work for you:
Lightning to USB Cable 1
Feb 04, 2016 | iPhone 5c Cell Phones
Change dock connector
Though I'm not sure, I think what you are asking is how to use an iPhone 5s on an older iPhone docking station. If so, my recommendation is to buy and a 30 pin to 8 pin adapter. Here is an example:
http://phonepartsusa.com/adapter-30-pin-to-8-piniphone-5-ipad-4-ad?language=en₪cy=USD&gclid=CJbTm_u188MCFUZhfgodt2wA9Q
Apple sells one as well called a Lightning to 30-pin Adapter for about $30. Here is that link: http://store.apple.com/us/product/MD823ZM/A/lightning-to-30-pin-adapter
It all depends on the form factor of your dock and whether the added size of the adapter will still allow your phone to sit on the dock. There may be some smaller, slimmer ones. If the phone doesn't fit on the dock with the adapter in place, you could also buy a iPhone 5s extension cable and just cable your phone to the dock and adapter.
Feb 21, 2015 | Apple iPhone 4S
Is there an adapter/cord (30 Pin to Lightning, or 30 Pin to Bluetooth) actually KNOWN to work with the Altec Lansing iMT800, so we can all charge and control the newer Lightning connector style iPhone
I think your only option is to get one sold in Apple stores. I have a small 30-pin-to-Lightning adapter (not a cable) and it does not work with either my iPad mini or my wife's iPhone 5. I also have a non-Apple Lightning charging cable (as a backup, just in case...). Same deal.
Dec 16, 2014 | Altec Lansing inMotion MIX iMT800 Portable...
Socblue a860
I saw the A860 on youtube.
Should you jailbreak the phone first, to get the app for socblue?
If you keep having trouble with the 4 sim, try to uninstall the app, and reinstall it.
This is the only thing I can think of.
iPhone 5 Multi SIM Adapter Online 5 SIM active simultaneously SIMore...
Jul 11, 2014 | Apple iPhone 5S
New iphone 5 does not fit on the base
They do make an adapter that you can purchase from the Apple store. This was a common issue when Apple switched from the 30 pin connectors to the new lightning ports which are much smaller.
Hope that helps!
Dec 04, 2013 | Brookstone Idesign Wafer Cd System For...
Hp g50-213CA wifi
Try using just "numbers" as password for you iPhone 5 personal hotspot.
Nov 20, 2013 | HEWLETT-PACKARD G50-213Ca Ac Adapter...
Iphone 5 does not charge, nor does music come through the speakers when connected to the Jensen 205i docking music system via 8 to 30 pin adapter.
Hello Karan,
Thanks for choosing a Fixya.
As far as i know & from experiance of using Apple Product since many years, some times some accessories does not supports & works very well with iPhone. If your iPhone is working fine with other accessories that mean original accessories came from Apple then there is nothing wrong with iPhone, so please try it with another system or try with another 30 pin Apple original dock adapter & i hope it will work like charm.
Thanks & Regards,
Chandrashekhar !!
Aug 20, 2013 | Jensen JIMS-205i Docking Digital Music...
IPhone 5 charger
Yes! You can use your old chargers with the iPhone 5 however you will need to buy the adapter for them so that they will be compatible with the new "lightning" sync connection. You can read about it here: http://store.apple.com/us/product/MD823ZM/A/lightning-to-30-pin-adapter?fnode=48
Sep 16, 2012 | Apple iPhone 5
Iphone connection with router
In order for your Iphone to connect to N network you need to make sure that Iphone supports 5 Ghz network. I believe Iphone only supports 2.4 Ghz and that is why you can not connect it to the 5 Ghz (N network) of the router.
Hope this answers your query.
Regards
Anand
Feb 25, 2010 | NetGear HDXB101 Powerline HD Enternet...
Panasonic SC-HC271 iPod Dock/CD Player Micro System Logo
15 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
