Question about Gaggia Brera Coffee Maker
Water leaking in grounds container
Getting wet coffee grounds in grounds container
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: gaggia syncrony compact leaking water where
If you remove the tank, does it leak? If yes then check the spring loaded valve under the tank, also check the O-ring for damage.
Posted on Jun 06, 2009
Ground coffee does not get wet
try to fill the reservoir with the water to the top, when the water starts "brewing" the water is transfer from this reservoir to the basket where there is loose coffee placed over the paper bag that will filter the coffee to the jar.
Check if anything is blocking the canal, that is transferring the water from the reservoir to the basket.
Mar 01, 2015 | Cuisinart DGB-550BK Grind-and-Brew 12-Cup...
Empty ground container issue
Once you have the drip tray out and the grounds container out - look inside the unit and clean any grounds that are still in there. Look for a switch that might be sticking (because it's cover with coffee residue) clean everything and check for freedom of movement.
Nov 27, 2014 | DeLonghi ESAM6620 Prima Donna Bean-to-Cup...
No coffee will come out
Maybe the coffee is down, around the waste container. In this case the grinder must be opened probably the cofee funnel is jammed or is not in his place to direct the grinded coffee.
Jul 29, 2014 | Saeco Odea Giro Plus Coffee Maker
MY Saeco italia has been leaking everytime it pulls a shot from the bottom of the unit. I opened the machine and the steam valve area is dry as with everywhere else. The only part that's wet is the...
it is also possible that the leak came from the pump as well most likely your lines are also clogged up with fine ground coffee past the brewer which stops the water from flowing and causes excess pressure which eventually either busts a water line or makes the pump push the water out past the caseing of the machine. Very time consuming finding the leak as well as replaceing the parts that are broken. If you have any further questions message me back. Thanks
Rick
p.s just curious because i ask all customers dealing with coffee and expressor machines what was the grind set to when you ground your coffee?
Sep 28, 2011 | Starbucks Saeco Italia Digital Barista...
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
Gaggia Brera Coffee Maker Logo
23 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
