Question about Rheem Heating & Cooling
Water starting coming from my rheem model RCGA-60A1AS24
    Top Expert:
  • Rheem Master
  • 8,488 Answers
Freezing up possible low freon
Posted on Sep 16, 2017
2 Suggested Answers
  • 832 Answers
SOURCE: Not heating. The fan blows, but no warm air
Please check if the compressor is running, if not, then
there is no warm air generated. Please contact the RHEEM dealer about it. Aircon compressors are run
with a thermostat. So, you may try setting the aircon
thermostat to maximum, so that the compressor run,
and you can have your warm air. May this info help you.
Posted on Jan 10, 2010
Just bought a honeywell thermostat that needs a c common connection. I only have 4 wires coming from the system, where do I suppose to connect to or add the C ground cable. I have a rheem rcga-60a1as24....
Your thermostat wiring going to thermostat should have extra wire on it .Just uesd one to connect common and the same wire connected to common on your furnace .Also you can used the common from transformer which will also work
Feb 16, 2018 | Heating & Cooling
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
Not heating. The fan blows, but no warm air. RHEEM RCGA-60A1AS24
Jan 10, 2010 | Heating & Cooling
I have a Rheem glas fury model 22-40 gas water - leaking
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Oct 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Apr 04, 2009 | Water Heaters
Heating & Cooling Logo
66 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
