Question about Kodak EasyShare C330 Digital Camera
Problem with camera
My camera will be working just fine for awhile and then out of nowhere it will say memory card full, when it IS NOT full. Then it won't let me review or take pictures. If I plug it in to download the pics off, it won't download all of them, I have to take the memory card out and plug it in directly to the computer and clear the memory card through the computer. We got this camera & memory card in August of 2006.
  • 3 more comments
  • Anonymous Sep 27, 2007
    it's 512 mb and I know it's not full because I've used the camera for a year and it holds more than 11 pictures.
    And yes, read the manual.
  • Anonymous Sep 30, 2007
    Figured out the problem, bad memory card.
  • Anonymous Dec 01, 2007
    brand new SD 2GB memory card inserted. displays memory card is full or simply: reading memory card. nothing else happens. unable to take pics unless use internal memory which works fine. many thanks for any advice.
  • Anonymous Jan 25, 2008
    I bought a new 512mb memory card and haven't had that problem since BUT now when I plug my camera into my computer it displays that there are no new pictures and if I take out the memory card and put it directly into my computer it reads it just fine. Any ideas on this new problem?
    Thanks for your help!
Jackboy, I don't think the filetype has anything to do with it. Why? one user said that he used a 2gig SD card! The problem is the firmware needs updating or the camera cannot handle large memory cards at all (512MB and more...1-2gig do not even read). I saw this problem on someone's c330 today.
Posted on Jan 23, 2008
    Genius:
  • 2,985 Answers
How do you know it is not 'Full ? How many images do you expect it to hold? What size is the Card? What type of image are you trying to store -RAW TIFF Jpeg ? Have read the manual by any chance /
Posted on Sep 27, 2007
  • Anonymous Sep 28, 2007
    The number of images a 512 Mb will hold depends entirely on the size of the file.
    There are several file qualities which on a 4 Mp camera with a 256 Mb card will give
    RAW 16
    Tiff 10
    SHQ 44
    HQ 142
    SQ 2348 images approx
    You camera may not access all theses file options but will do some -say the middle band
    YOO HAVE GOT IT SET TO A HIGH QUALITY BAND AND IT NEEDS 'STEPPING' DOWN
    E.G. read the manual- look at your menu options
    you may be best refer this to the Maker support line.
    The camera is operating fine - takes images
    But is not reading them
    This suggests a firmware failure of some sort
    This may be correctable by a download or it may mean replacing the camera
    When cameras fail in the main circuitry there usually no 'repair' option
    If it is known problem the camera will be replaced.
    If it is a general service failure[age] then it will be new camera time
SOURCE:
No memory card message
try another memory card and if that doesn't work you should probably go to a local camera store or the place you bought your camera
Apr 16, 2013 | Sony Cyber-shot Dsc-w610 14.1MP Camera...
7D wont work. It switches on but wont take a picture and the menu screen wont come on
Try formatting a memory card and trying it again. If the buffer is full and the card is full or corrupt the camera cannot take another image because it has nowhere to put it. Corrupt cards can cause a lot of problems Formatting cards regularly will made a big difference is camera performance. JUST BEWARE, FORMATTING PERMANENTLY ERASES ALL MEMORY CARD DATA., So copy the card info over to a HHD, or flash drive before you format.
Jan 01, 2013 | Canon EOS 7D Digital Camera
Not reading the memory card
You need to get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Now, your card should work properly.
Apr 24, 2010 | Kodak Easyshare M753 Digital Camera
A 2gb memory card says memory full tried it in
No, that camera works with the 2gb cards just fine. You will want to try to format the card in your computer first, then try it in your camera (format it in the camera before using). If it doesn't format in the computer, it is a bad card.
Jul 19, 2009 | Kodak EasyShare C330 Digital Camera
Kodac easy share c330 says memory card full, but it is a new card
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 03, 2009 | Kodak EasyShare C330 Digital Camera
Cant review pics on camera or computer, but camera says card is full
This occassionally happens with memory cards formatted using FAT. The simplest way for you to get the pics of the card when such a thing happens is to get a card reader. Pop the card in to the card reader, connect it to your PC and transfer the pics. Then format it using FAT32. I have noticed that my card was a lot more reliable in saving pics compared to FAT.
Apr 13, 2009 | Sanyo VPC-S7 Digital Camera
KODAK CAMERA MEMORY INTERNAL WORKS FINE,MEMORY CARD WILL NOT,SHOWS CARD FULL, CAMERA WILL NOT WORK WITH CARD,help,
Please test with a dif. SD card.
Download the firmware:
http://wwwuk.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=7148/7151&product=EKN030243
Pls. bear in mind that this model only supports:
SD/MMC up to 1 Gigabyte
If everything fails.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Jan 18, 2009 | Kodak EasyShare C330 Digital Camera
Vivitar Vivicam 3715 can't format new 2gb SD card. Card OK!
What information is given in the manual ?
BTW, AFAIK, 2gb SD cards and 2gb SDHC cards are not interchangeable - do you have the correct one ?
Jan 13, 2018 | Vivitar ViviCam 3715 Digital Camera
Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
Memory Stick Error
memory connector in camera may have loose or corroded pins ( memory card will not seat ) ; consider replacing connector - if cleaning and resetting connector pins does not help ;
Aug 01, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
106 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
