Question about Soundstream VIR-7870NRB Car Video Player
My hv4000 video captur dvr card stopped working
Tip
How to convert analog video to digital format.
<p>Equipment needed <br /> <p> <br /> <p> <ol> <li>PC</li> <li>Analog Capture Card (you can find prices here)</li> <li>Sound card (some capture cards has their own audio input)</li> <li>Cables</li> <li>VHS Player/Camcorder</li> <li>Capture Software (Windows Movie Maker 2 can do this)</li></ol><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p>Steps to perform<br /> <p> <br /> <p> <ol> <li>Hook up your capture device to your computer</li> <li>Turn on your PC, install the drivers</li> <li>Hook up your analog player to your capture card with the cables</li> <li>Load your capture software</li> <li>Set the capture options (video and audio)</li> <li>Start the capture process</li> <li>Start the playback on your analog device</li> <li>Once the analog device has finished, press stop</li> <li>Stop the capture process</li> <li>Save the video</li></ol><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p>Remember, you capture card merely records the signals that comes from you analog device. If the footage is blurry and choppy, it's probably because of aged tapes or dirty video heads.<br />
on Nov 30, 2010 | Computers & Internet
I purchased a kit and my dvr stopped working
ardupilot.com - View topic - 3DR Video/OSD Kit stopped working
ardupilot.com/forum/viewtopic.php?f=72&t=10613
Dec 11, 2014 - 8 posts - ‎2 authors
I purchased the 3DR Video/OSD kit a few months ago. ... Yesterday, I went to test mysystems, and noticed it was not working. .... That test was captured via my DVRcapture device, while the outdoor image was a photo of the ...
TiVo Repair and Troubleshooting - Weaknees
www.weaknees.com/repair.php
General TiVo/DVR Problems and Troubleshooting ... Hard Drive Replacement Kit ....Purchase a WeaKnees TiVo Modem Replacement Kit; Have your internal ...
Bunker Hill Security 4-channel Surveillance DVR w
www.amazon.com/Bunker-Hill.../B005TIE70C
Amazon.com, Inc.I've since purchase another DVR KIT one for my backyard and have caught ..... Both systems stopped working within 2 months of each other in April and May of ...
Reviews - Maplin
www.maplin.co.uk/p/sentient-160gb-4...kit.../all
Maplin ElectronicsBought this kit about six months ago and worked brilliantly without any problems. Then the network part of it stopped working, it wouldn't recognise any ethernet ..... I boughtthis CCTV with DVR as my wife's car had been rifled by someone a ...
How do I reconnect my DIRECTV HD DVR to the Internet ...
Jan 13, 2016 | SWANN Home Security
Drive easycap win8 64 USB 2.0 Audio/Video Capture/Surveillance Dongle
Easycap dc60, like everyone found out it doesn't like to play with windows 7 64bit.
Try this site
STK1150 Driver for 32bit
STK1160 Driver for 64bit
https://visser.io/2015/06/easycap-drivers-for-windows-8-1/
aka Easycap 4Ch USB DVR W10, W7, x64)
Jun 28, 2014 | Universal EasyCAP USB 2.0 Audio/Video...
Tech support
DVRs store files on either data tapes or on hard drives or on memory chips such as SD cards. If SD card then simply remove the card and plug into a computer where it will appear as a removable drive. If internal hard drive your DVR will be equipped with either a IEEE1394 mini socket or a USB mini socket. In either case plug the appropriate cable from your DVR to your computer where it will appear as an external removable drive. If you are talking about a proprietary DVR such as a Foxtel IQ or other brand name DVR then you have to know the format of the video files. Foxtel, for example, uses their own format which can be recovered and saved to an external hard drive on a computer using a video capture card and playing the file back in real time. Time consuming, but that's how I do that. Other branded DVRs use standard video file formats that can be copied to your computer easily via an HDMI socket or USB3 or whatever it has.
Dec 09, 2013 | Audio Players & Recorders
Getting error DVR CAPTURE BOARD IS NOT FOUND
Sounds like you DVR Card has glitched or faulted, to tell, remove card form PC, and turn on, wait for 5 mins, and turn OFF, now re-insert the card, use another "Socket" if you want, or if it doesn't work first time, try another socket and try again, and turn ON. IF the Card is detected, then it will most likely be OK, simply Point it to where the "Drivers" are. and it will install and should be all good. IF it is NOT picked up and doesn't install drivers, then your card has developed a fault. You need to get another.
Apr 30, 2010 | Video Game Consoles & Games
How to transfer files from sony digital video camera recorder dcr-trv265e pal to my windows xp computer?
If your camera has FireWire, you can install a FireWire card, Or USB "Dongle" into your PC, Or you can install a TV/Video "Capture" card Or USB dongle, to your PC, then using Video Capture Software, essentially, making the PC into a DVR, you can then record, and save it to disk, and then you can do with it whatever you wish.
Apr 01, 2010 | E.Digital Sony DCR-TRV265E camcorder Pal
GeoVision Gv650 vs Video ATI X300
This PC has a ATI motherboard chipset, which is incompatible with GeoVision. GeoVision does not work with ATI or Via motherboard chipsets. ATI graphics cards are not an issue.
Oct 08, 2006 | Geovision GV-650 BNC (GV6504) Video...
Soundstream VIR-7870NRB Car Video Player Logo
14 people viewed this question
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
