Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
RF540 A Fisher-Paykel Water dispenser not working.How to take off the front display panel?
  • 17 Answers
SOURCE: Fisher paykel dd603
Pull the bottom drawer out !!!!! To do this on the left and right sides of the bottom drawer you need to pull the pins (Plastic) then pull it out it has hoses still connected pull out and turn on side look in the back left corner (with Pwr off) there is a board there and it has a water (Flood sensor) on it make sure it is dry this is what the Fault code is
Posted on Dec 03, 2007
  • 27 Answers
SOURCE: Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Posted on Jul 15, 2008
  • 26 Answers
SOURCE: Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Posted on Mar 10, 2009
SOURCE: Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
Posted on Dec 13, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
Fisher & Paykel fridge the water dispenser on the front of fridge is locked how do you unlock it.?
Hello Patti Emelson,
Let's say... (for example)
Your model number is E522BLXU...
on that model... (Fisher & Paykel)
Page 10 of those
instructions
says of manualslib.com (URL link below)
Dispense LOCK
This mode disables the water dispensing pad & prevents water
from being dispensed.
To activate this mode, press the MENU and MEASURED FILL
keys together for two (2) seconds...
Of course the precise buttons could vary... WHICH is why
putting in TOUR MODEL NUMBER is important for
such questions ...
Reference
Fisher Paykel E522BLXU Service Manual Dispenser Lock Key Presses measured...
Hope this helps
Carnac the Magnificent
Oct 21, 2017 | Fisher Refrigerators
I have to replace the dispencer control panel (part#821074P) on Fisher Paykel e522b with water dispencer, how can i remove the front cover to get to the electronic circuit panel
Disconnect the refrigerator from the power supply.
Looking up at the dispenser, Push the 2 outer tabs upwards and gently pull the panel forward once the tabs release.
A small screwdriver or key may need to be used to dislodge the tabs from the housing.
Two locating pins on the base of the front panel hold the housing at the bottom.
NOTE: The housing cannot be removed, as wiring looms prevent its removal.
To refit new module, perform in the reverse order.
Oct 02, 2016 | Fisher and Paykel Refrigerators
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Fisher snd paykel e522b ice snd water frudge not dispensing chilled water. Also only half display is working.
U may need to get it re-gassed? or it may be a wire running to the water chiller
Oct 31, 2013 | Refrigerators
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Jul 01, 2008 | Fisher and Paykel Active Smart® E522BR...
Fisher & Paykel GWL08 top load washer appears a crack in the inside water dispenser
With the lid open, you'll see two white plastic plugs on the top front lip of machine. Pry them up with fingernail to reveal screws to remove. Take care not to let top flop back as plastic tabs may break.
May 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Machine cant get any water.
Does the water fill to the correct level ?
Sep 09, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
400 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
