Question about Caterpillar Toys
I have a Dynahoe 490 backhoe. I want to take off one of the pistons because it is leaking, but the 1/2" plug seems a bit big. Why doesnt it fit... Also need a piston rebuild kit
  • 142 Answers
SOURCE: I'm 5400 ft and running a 490 main jet. the plug
try a cooler range plug with the same jets and see w
Posted on Jun 02, 2009
MakisRC51
  • 408 Answers
SOURCE: NEED PISTON KIT ,ALREADY HAVE THE RINGS
Try to take with you one of the old ones and go to a Wiseco's dealer store.Perhaps you find there.Honda OEM parts does not provide anymore?
Posted on Jun 03, 2009
czaa
  • 4521 Answers
SOURCE: I need a cylander,head, piston and bolts to rebuild it.
search archway mc salvage in st louis may be able to salvage piston-try getting a mc rebuild manual
Posted on Jan 11, 2010
  • 49 Answers
SOURCE: cant find piston kits
j&e custom pistons
Posted on Jul 06, 2010
kirkx
  • 2019 Answers
SOURCE: I need to rebuild both of my front calipers on my
If by "disassembling the calipers" you mean splitting them open, DO NOT do that.
You detach the caliper so that you can remove the pads and get at the piston, but then what you should do is to simply pop the piston out.
That can be done simply by pumping the brake pedal, using air pressure (with a rag to prevent the piston from flying around), or with a grease gun.
Then once the piston is out, you simply wire brush any corrosion off. If the piston is so pitted that it can not be made smooth and will leak, then it should be replaced.
If you wash them out with anything other than brake fluid, then be sure to blow out any residue with compressed air.
Use lots of brake assembly lube, and ensure the new dust seal is water tight. Bleeding the brakes will flush out any remaining dust.
Posted on Oct 04, 2010
My opel kadett 1995 model it burn the plugs and the fuse what can course that.
a bit unusual that
are you gaping the plugs to spec before fitting
if so .....try a hotter range plug
or fit iridium's ..last much longer
which fuse keeps blowing ?
it may lead to a solution for you
how is the fuel consumption /oil usage ?
i was thinking of these causes
has 16 valves - valves are burnt or leaking
-over heating coil ,or exciter or resistor
-too much fuel in the combustion chamber
...burning oil , weak piston rings
Oct 14, 2016 | Opel Cars & Trucks
Motor coughs and splutters upon acceleration
Hi Anonymous, if you have a carbuerator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Please visit the website below for a prime suspect:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley... Good luck
Feb 09, 2014 | Harley Davidson Motorcycles
How do I fix a vacum leak on 2002 nissam sentra gxe
You have to find the leak and seal it up, hey. It may help to picture where vacuum originates in the engine: As the pistons move down in the cylinders they pull air in from the intake manifold. This creates a pressure drop in the intake, a vacuum that is maintained as the engine is running. New air that is pulled into the intake is measured by the Mass Air Flow sensor mounted in the big boot between the air filter and the intake. If extra air is pulled into the intake manifold from a vacuum leak, uncalibrated air, the computer can figure it out from the oxygen sensors reading in the exhaust-mixture is too lean, so the computer will try to compensate by delivering more fuel, but can't deliver enough, mix is still too lean, so computer sets a code for the vacuum leak.
The intake will have a few vacuum taps with hoses running to engine or car controls that require vacuum to operate. If one of the hoses comes off or has a leak, that is extra air into the intake. Your power brake booster has a large vacuum tap. That may be the problem. With the engine running, pull off that line and plug it, and see if engine speed changes. If the idle drops that may be your leak-a failed power brake booster.
If nothing yet, keep engine running and spray some starting fluid around the mounting area of the intake manifold (maybe the intake gasket has failed and sprung a leak) and listen for a change in engine pitch or speed. The fluid may get sucked into the intake and cause speed to change. If it does, you would need to remove the intake manifold and fit a new manifold gasket.
Also check the big boot from the air filter to the throttle body for tears or loose fit. Good luck, Rev!
Nov 30, 2012 | Cars & Trucks
Makita MAC5200 Compressor. Leaks air around the regulator screw in adjustable black knob only when I turn up the regulator pressure to allow air to flow through to the quick connects. I've taken the...
There are two types of regulators used. One has a rubber diaphram sealed at perimeter with body and a piston type. Most likely you have the piston type. Remove body containing piston/ spring mech. Examine piston lip seal. Lip will face toward body of reg. and must fit snugly into cylinder. Make sure cylinder is smooth and is well lubed.
If seal/piston fits loose remove seal and wrap some teflon tape in groove and re-install lip seal /test for snug fit. Notice small metal actuator extending from center of reg. , if it is circular (about 1/8 dia) then there should be an oring of the same size mated/fit into the piston. If this oring is missing it will leak as you describe. Lastly, there should be a gasket or oring sealing outer shell to body. If you have diaphragm type look for holes, tear or shrink too small. Parts are at www.toolpartsdirect.com or Lowes in the plumbing department good place for orings and silicone lube. Good luck
Sep 27, 2010 | Makita MAC5200 Electric Powered Air...
Installing distibitor 1997 5.7vortec
with # 1 piston (front piston on drivers side) on tdc compression stroke place distributor in pointing at the front of the drivers front tire as it drops in it should point roughly at the # 1 piston as it rotates clockwise as it drops in , the cam gears have to mesh so dont force it . if it wont drop into place try a small bump of the starter while applying light pressure down on the dist.it should drop into place and then lock it down a bit . get #1 piston back on tdc compression stroke make sure the power wire is off the dist . the big red 1..you dont want it having spark yet. if it goes into place then set your cap and wires back in and time it with timing light .remove vacum hose from vacum can on side of dist and plug the hose off then use timing light and set to what factory says , usually between 4-8 degrees btdc. 1-3-5-7 piston numbers front to back drivers side ///// 2-4-6-8 front to back on pass side firing order is 1-8-4-3-6-5-7-2 and the dist should have #1 pointing at the drivers front corner of engine. start # 1 plug wire there and work clockwise next spot clockwise on dist is #8 plug wire and so on.. good luck
Nov 19, 2009 | 1997 Chevrolet K1500
Splice valve backhoe controls
If it had long bolts running through it from end to end it has O seals for sure and can be fixed - but do it on the bench in the clean and dry as there will be all sorts of bits come out as well .
If no long bolts its just the ones round the spools under the lever covers .
Oct 14, 2009 | Garden
Cannot fit caliper w/new pads on rotor(rear brakes)
Squeeze the pistons with large pliere to get a little more clearance
Aug 30, 2009 | 2006 Ford Five Hundred
May 15, 2009 | 2004 Yamaha YZ 125
Tips on changing plugs for the first time
I have never changed the plugs on this type of bike but here is a rough idea for you.
Dissasemble:
1. Remove the fuel tank making sure you dont spill any fuel
2. Remove the Airbox
3. Number up the plug leads (mark them numbers 1-4) making sure you dont get them mixed up i.e no.1 lead resembles piston no.1, no.2 lead resembles piston no.2 piston and so on
4. Remove the spark plugs with a correct size spark plug socket
Installing:
5. Before installing the new spark plugs make sure you have made the right gap clearence on the tip of the plug
6. Install the spark plugs
7. Re-fit the leads making sure the correct marked up lead goes with the correct piston
8. Fit the airbox
9. Fit the fuel tank
Hope this is help to you. If you are in doubt then take the bike to a nearby mechanic in which i should imagine that it is not expensive to have them fitted professionly
Apr 21, 2009 | Suzuki GSX-R 750 F Motorcycles
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
Toys Logo
47 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
