Ip7200 printer keeps telling me that it needs paper when paper tray is full
leroyal
  • 2120 Answers
SOURCE: CLP-500N Paper Tray error
It wants you to put paper in the multi-purpose or pull down tray 1 assembly.
Posted on Jan 05, 2009
  • 461 Answers
SOURCE: My printer c5280 keeps saying please reinsert or lower photo tray
This model appears to have several trays for print media see the manual. Check the default print settings by right-clicking on the printer icon in the Printers and Faxes folder and see that the default is set to what you print most. Also verify all trays are inserted properly and that you have plain paper in the paper tray.
Posted on Jan 17, 2009
yooperbud
  • 8637 Answers
SOURCE: Paper Tray Error CLP-500N
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
SOURCE: Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
  • 685 Answers
SOURCE: HP J6480
Try this...
Posted on Oct 28, 2009
My canon printer ip7200 indicates ink absorbency is full. How do i clear this error
All inkjet printers have a cleaning process that must be performed occasionally; there'll be something listed in the owner's manual (if you've misplaced it Canon's website has them in download form) Also, every inkjet has a little "sponge" offset to the side of the paper path where the print head ejects ink as part of its initializing process. It may just be that your printer can tell that this pad is full and needs to be replaced.
Jan 02, 2017 | Canon Office Equipment & Supplies
I keep getting error sayng to remove paper from tray after I try to print. Any thoughts?
In the paper output tray there should be a tab in the center that you can move up and down easily. It sticks out in front of the rollers. It moves up to "tell" the printer that the output tray is full. Check to see if that tab got stuck in the up position. That would cause it to think there is too much paper in the output tray and tell you to remove it.
Give it a go and see if that helps. Good Luck!
Aug 18, 2010 | Ricoh Aficio AP610N Laser Printer
Cant pick up paper
the dock will not pick up paper lost my manual i tried one piece half full tray and afull tray it worked last time i printed what up
it keeps saing its out of paper
Jan 19, 2010 | Kodak EASYSHARE G610 Thermal Printer
I had a paper jam and after I unjammed it the paper will no longer feed into the printer. It keeps telling me the tray is empty when it is full
Unplug from the power then restart the printer sometimes the paper is not in just right and when you restart the printer it will send any loose paper on threw the printer
Sep 29, 2009 | HP Photosmart C6280 Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
Keeps telling me to put paper in tray-tray is full
It sounds like it has lost how to detect the paper tray, this could be possibly the paper tray itself or the configuration on the machine its self, look on the tray and see if it has a paper configuration slide or a magnet on the side or front that is missing, or you will need to go into the menu configuration and choose the paper tray.
Good Luk
Jan 29, 2009 | Sharp AL-1655CS Copier
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
320 people viewed this question
k24674
jasbo
jasbo
